Question about MGE Galaxy 3000 UPS System
What batteries go in this unit how many 12? need a replacement
I need help
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
8.3 Battery Configurations
There are different configurations for different battery types and backup time. Here, the batteries from VISION and
YUASA are selected. The backup times ranges from 1hours to 4hours for 20KVA UPS and from 1hours to 2hours
for 30KVA UPS, because of limitation of CLA power rating.
UPS Backup
time Number of blocks Type of blocks Capacity(10H)
1h 1×24 6FM55SGX 52Ah
10kVA 2h 2×24 6FM45X 2×42Ah
4h 2×25 6FM75X 2×74.5Ah
1h 24 6FM75X 74.5Ah
15kVA 2h 3×24 6FM45X 3×42Ah
4h 3×25 6FM75X 3×74.5Ah
1h 1×25 6FM90X 90Ah
20kVA 2h 3×25 6FM55X 3×52Ah
4h 2×26 6FM150X 2×144h
1h 2×25 6FM75X 2×74.5Ah
30kVA
2h 3×24 6FM100X 3×96Ah
Sheet. 4 the battery configuration with VISION battery
UPS Backup time Number of
(10H)
1h 2X24 NPL24-12 2X24AH
10kVA 2h 2×26 NPL38-12 2×35.3AH
4h 2×26 NPL65-12 2×60.5Ah
1h 1×27 NPL65-12 60.5Ah
15kVA 2h 2×24 NPL65-12 2×60.5Ah
4h 3×26 NPL65-12 3×60.5Ah
1h 1×27 NPL100-12 92Ah
20kVA 2h 2×24 NPL100-12 2×92Ah
4h 4×26 NPL65-12 4×60.5h
1h 3X24 NPL65-12 3×60.5Ah
30kVA
Posted on Feb 04, 2015
I need to find out a replacement battery for the above. The unit is about 4 years old.
Dear Luke Edmunds
you can replace with 12 V x 16 A x 2 CSB
it is original batteries of APC unet
Mar 25, 2015 | APC Computers & Internet
I have an APC BE350U battery backup. When power is removed, all connected equipment stops and the unit beeps four times every 30 seconds. I have removed the battery from the case and checked the power...
The output on the battery should be around 14V, not 115V. If the unit is not holding the equipment powered when you remove the power, you need to get a replacement battery. The BE350 uses a 12v 3.5. Make sure to buy a high quality battery in order to get a good and reliable run time.
Jan 29, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Garmin gps 12 loss of data
I had the same thing happen. The problem is that the internal lithium battery is shot. Solution: phone Garmin at 1-800-800-1020 x 2,2,1. You send the receiver in along with a $42.41 check. They will probably replace the unit. They will explain exact procedures when you call.
Hope this helps.
Joan
Jan 04, 2010 | Garmin GPS 12 GPS Receiver
The light don't come on and want charge my 12 volt battery
My charger has a fuse located on the circuit board inside the unit....when mine stopped working, it was the fuse...replaced it and it is working fine for one battery, the other blows the fuse every time....bad battery.
May 20, 2009 | Black & Decker Black And Decker 12 Volt...
Internal battery dead,how to replace
The GPS 12 has an internal battery soldered to the board inside the unit.
I have replaced about a dozen of these over the years,
The problem is caused when the unit is stored for a long time without batteries.
The internal battery is not a rechargable.
You have to use a screwdriver in the crack that joins the 2 parts of the case and break the seal to split the case open.
This will of corse render the waterproofness of the unit void.
You then have to unsolder the internal battery from the board and find a replacement.
It is a tagged lithum battery, I can't remember the model at the moment.
Inside you will also notice the surface mount Intel 386 Chip. which is the main processer.
This has nothing to do with the battery but I found it interesting that a chip in a computer from the mid 80s worth over $3000 then, still has a use.
When you have soldered the new battery into place you need to either glue or tape the unit back together. Be careful not to damage the other parts around the battery.
Always keep charged batteries in the unit when not in use.
Hope this helps.
Alan
Apr 12, 2009 | Garmin GPS 12 GPS Receiver
Cyberpower 725SL Intelligent Back Up Power: This unit now just flashes on / off. When I press the red button and then back on again - it continues to flash on / off. I have tried plugging it into other...
It would appear that you need to replace the battery on this unit.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (BP9-12 battery).
We have a 3 year warranty on all our battery back up units. If you have any questions, you could contact us here at CyberPower Systems Technical Support at 877-297-6937, M-F 8-5 Central, or email us at tech@cyberpowersystems.com.
Nov 03, 2008 | CyberPower 725SL UPS System
Battery replacement for unit
The unit itself is obsolete.
However....
Open the unit up (six cross-head screws). Inside you'll find a 12V 5.0AH rechargeable battery, like the kind used in many home alarm systems.
You can get a replacement at most battery stores (they'll even pre-charge it for you). Somewhere around $20, I guess.
Sep 12, 2008 | Black & Decker String Trimmer Cordless 12"...
Belkin F6H650-USB
If you did not take a lighting hit everything should be OK. Plug a light or another electircal device in to make sure each socket works. If not you have a problem I recommend to replace UPS. Your UPS should show a low battery LED. Here is a link for your manual for your model UPS. If you need any more help let me know?
http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/f6h-ser-user%20manual.pdf
Jan 02, 2008 | Belkin Home Office UPS System
Garmin StreetPilot C330 GPS--Battery
The batteries on the units are not meant to be serviced by the unit. If you are not familiar with taking it apart, you may damage internal components in trying. If the unit needs service, it is best to return it to Garmin and let them take care of the repairs. As far as the battery not holding the charge, if you have not done so, charge the unit on the computer for a few hours. This sometimes helps.
Nov 26, 2007 | Garmin StreetPilot C330 GPS Receiver
The battery plug in area is dead but the surge protector side works
Hello Vicki,
What you are describing is usually a result of the batteries losing their ability to hold a charge.
The surge protector side does not rely on the batteries.
I found good batteries at a reasonable cost on ebay, but I think you're going to need to replace batteries at this point.
Hope this helps.
Charlie
Nov 18, 2007 | Cybernet Systems CyberPower 625AVR...
Computers & Internet Logo
182 people viewed this question
Top MGE Computers & Internet Experts
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
