Home | HP | Thin Client - AMD Geode NX 1GHz - 256MB DDR... | Change operating system
HP Thin Client - AMD Geode NX 1GHz - 256MB DDR SDRAM - 512MB Flash - Windows XP Embedded - Tower HP Com... Network Terminal
Problem for HP Thin Client - AMD Geode NX 1GHz - 256MB DDR SDRAM -...
By laringtage on Jun 15, 2009
i want to change my operating system from windows vista to windows xp, my laptop model is HP pavilion dv5 series.
Best Solution
posted on Jun 15, 2009
Helpful)
sabharish
Rank: Guru
Rating: 85%, 229 votes
You can keep both Vista and XP. Below is the way to install XP, after Vista was already installed... creating a dual boot. First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive. Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. Next, insert your Windows XP CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating system files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive. Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component. Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to. And now you should be able to dual boot between Vista and a previous OS. Thank you! Sabharish
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
efs_perpends
Rank: Guru  HP Expert
Rating: 89%, 690 votes
Please consult links here, here and here before you make this change, as the functionality of your system could be adversely affected. Make sure you can acquire all needed drivers before you abandon vista. For a tutorial on updating drivers see here.
If you're having issues with vista performance, consider upgrading your ram, make sure you have all the latest driver updates, as a lot of manufacturers took some time to get their drivers up to snuff after vista was released,
See MS articles on vista performance here,
and a very helpful vista forum here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Was this helpful?
Yes
No
Popular Solutions for HP Thin Client - AMD Geode NX
Questions and Unsolved Problems for HP Thin Client - AMD Geode NX
Do you recommend HP Thin Client - AMD Geode NX 1GHz - 256MB DDR SDRAM - 512MB Flash - Windows XP Embedded - Tower HP Com... Network Terminal?
Answer
Answer
After the startup screen, the screen goes black with a message about analog screen resolution. How... (More)
Answer
Hi, I have just bought a hp officejet J4680 printer. My main concern is the fax. Can you tell me... (More)
Answer
I would like english instructions for the printer model HP Photosmart C4400 All-in-One series. We... (More)
Answer
I got this error while installing it through over Network. Fatal error during installation Module... (More)
Answer
I've had no ink level warnings and last time i used the printer it was fine. but today it's loading... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Thin Client - AMD Geode NX...:
Top Network Terminal Experts
Rank: Guru Guru
Solutions: 1501
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Network Terminal Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
