Question about Cell Phones
How to remove if on my phone show,s two times AM AND PM ROUND BLUE DOT
SHOWING TWO DATES ON MY CELL PHONE SCREEN AM AND PM AND ALSO IN THE PHONE BOOK NOT SAVING ANY PHONE NOS
Mark_Webber
  • 472 Answers
SOURCE: big blue dot
This is going to hurt..
You probably have a polarizer failing on one of the LCD panels inside.
There are 3 of these in LCD projectors, red, green, and blue. They all get the light fed into them, that light is then combined and fed through the projection lens.
You will need to contact Sanyo to find a service centre to replace it.
Posted on Apr 17, 2008
SOURCE: Cell phone dropped in water
you don't need to actually drop your phone in water for there to be water damage.
simple things like having your phone in the rain, in the bathroom while you shower, around a hot tub, or possibly even if it's really humid outside can set this water damage sensor off.
it just gives phone companies more ways to void your warranty.
hope this helped.
Posted on Jan 25, 2009
lukem9962
  • 144 Answers
SOURCE: phone is restricted
Recommended CODE :#pw+1530475760 +1#
  1. Remove SIM CARD !
  2. Type #
  3. Then press the * key 3times (you should get a "p")
  4. Then press the * key 4times (you should get a "w")
  5. Then press the * key 2times (you should get a "+")
  6. Then enter: 1530475760
  7. Then press the * key 2times(you should get a "+")
  8. Then enter: 1
  9. Enter: #
IF UNLOCK SUCCEEDS YOU SHOULD SEE RESTRICTION REMOVED ON SCREEN, YOUR PHONE IS NOW UNLOCKED!
POSSIBLE ERROR MESSAGES:
  • If you get CANNOT UNDO RESTRICTION your phone cannot be unlocked via code
  • If you get CODE ERROR the above codes do not work for your phone DO NOT ATTEMPT TO ENTER THE SAME CODE AGAIN
    Repeat above instructions, but with the numbers from code 1 (#pw+1530475760+1#) if code that does not unlock your phone STOP! .
  • try this 1
Posted on Apr 17, 2009
SOURCE: screen shows emergency @usb_isr
I DROPPED IT IN WATER IN NOW ITS SAYING EMERGENCY@USB_ISR IMAGE INVALID BOOTBLOCK VERSION:R500_BB:AL01.1
Posted on May 06, 2009
onyxvu
  • 74 Answers
SOURCE: Cell phone stuck on blue screen
were you trying to mod the phone? this is called a "bricked" phone. there is some file error in the phone. if you try pulling out the battery, sim and memory card. put just the battery in and start it up and see what happens- you might get lucky and have a fault with the sim or memory card. otherwise the phone is shot.
Posted on May 18, 2009
My phone is showing blue screen with "error fatal
1. remove the battery and power cable 2. remove the sim and memory card 3. reinstall eveything 4. estart your system
Jan 28, 2011 | LG Vu CU920 Cellular Phone
How can i get the houses of parliment with big ben on my phone it show day light with birds and dark blue with fireworks at night
Ensure that you have he phones clock set to the correct time. The application needs to have am/pm set or the time set correctly in 24hr clock format to work.
Jan 16, 2011 | Samsung SGH-S5230 Cell Phone
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
My nokia 5220 is showing contact service,what do i do?
First check self test to see if it's a HW failure or software.
The second thing to do is default to Factory settings. If the problem remain go to the next step
You may try to write full PM removing the simlock sectors. (I think it's 120 in new Nokia phones)
After getting a full PM without locks information connect the phone through FBUS, then selec SX4 AUTH. Press Service.
If the process finishes with no errors then select write PM and then push service. Now select PM.
Oct 05, 2009 | Nokia 5220 XpressMusic Cellular Phone
Incoming calls time and dates are not accurate
You have to program the corect date and time (make sure the AM/PM is correct) on the base unit. Then they should work fine. Good Luck
Jan 31, 2009 | Uniden 5.8GHz Dual Cordless Phone
Blank blue display screen
Have you tried opening the phone?Most of the time you can improve this by using alcohol and a tooth
brush to remove corrosion from the lcd power strip and the board,a little heat from a blow dryer helps.
Dec 30, 2008 | Sony Ericsson Z530i Cellular Phone
Screen goes blue
TRY DELETING THE BOOK. REMOVE BATTERY. RESET TO FACTORY SETTINGS
Aug 30, 2008 | Nokia 6070 Cellular Phone
Phone doesnt ring only vibrates
I had the same problem - on the left hand side of the phone (not the screen) if there is a red dot showing you have switched your phone to silent. Click the switch and your phone will ring
Jun 16, 2008 | Apple iPhone Smartphone
AT&T LG PHONE
Check whether your mobile's bluetooth is on, if on thats why u r gettings blue dot on screen
Nov 09, 2007 | LG KG800 Cellular Phone
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
