Question about TDK Audio Players & Recorders
Clock instructions for TAC4324
How do you alter the time
    Top Expert:
  • TDK Master
  • 75,452 Answers
Use Top Loader or Front Loader detergents Do you need to dissolve all powders or liquids before washing Can you alter spin time or speed
the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
Feb 24, 2015 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
How to change date on halda m12 taximeter
The date may change only as you cycle through the time setting in 24-hour increments. The date and time are interrelated.
Jun 05, 2014 | Humminbird Kienzle-Argo Taxi Meter 1150
Various questions re operation of LG Washer
In general, you do not need to dissolve powders before washing. In some cases, you can alter spin speed but not time.
Nov 22, 2013 | LG Washing Machines
How to fix the time and date
unscrew crown pull out to first position turn crown to alter date, pull crown out to second postion to alter time push crown back in and screw down
Mar 04, 2013 | Watches
When dose the timing belt need to be replaced?? My car is at 90060.
If I were you, I'd put one on before you hit 100,000
Dec 28, 2010 | 2007 Toyota RAV4
How to adjust the toasting time on the preprogram
your better off going back to the factory setting. Call turbo chef but here you go this is how you re-program the thing. Remember i took the time to give you these directions. Please take the time to leave a review
PROGRAMMING
Edit Mode
The EDIT MODE enables the operator to manually alter
recipes and the cook cavity temperature (CCSP).
To access EDIT MODE:
1. Simultaneously press the UP and DOWN keys.
2. When prompted, enter the access code “9” and
then press the ENTER key.
Altering a Recipe
Most NGC (Tornado) oven models contain 128
unique recipes. The display shows two (2) pages each
with eight (8) recipe groups. Each recipe group contains
eight (8) recipes. See Figures 11 and 12.
To alter a recipe:
1. Enter the EDIT MODE (see page 16).
2. Enter the access code “9” and set the CCSP. The
screen displays the first set of eight (8) recipe
groups. To access the second set of eight (8)
recipe groups, press either the UP or DOWN key.
3. Select the recipe group that contains the individual
recipe you wish to alter. Select the recipe you
wish to alter by pressing the soft key corresponding
to the recipe item. Figures 11 and 12.
4. Use the UP and DOWN keys to navigate through
the recipe settings. Use the keypad and ENTER key
to alter any of the following three (3) parameters
(see Figure 13):
a. Cook time
Total duration of the cook cycle. Enter the
desired time and press ENTER.
b. IR element temperature (IRSP)
The temperature the lower radiant element
will maintain during the entire cook cycle.
Valid temperatures are between 500ºF (260ºC)
and 1150ºF (621ºC).
c. Events 1…6
Use the keypad and ENTER key to enter values
for % TIME, % AIR, and % WAV.
o Sum of % TIME for all events must = 100.
The operating system will not allow a
combination of events not equal to 100%.
o The % AIR parameter is valid between 10
and 100%.
o The % WAV (microwave) parameter is valid
between 0 and 100%.
5. After making changes, test the recipe by
pressing the TEST soft key. Once the oven has
warmed to the CC set point, press the TEST
soft key again to begin the test cook.
6. Once satisfied with the recipe, press SAVE to
permanently store changes.
7. Press the BACK key until exited from EDIT MODE.
Jan 14, 2010 | TurboChef TORNADO Electric Oven
Electric Stove Model #YKERC507HW2 serial #IML0719161 Type 30 P Question: can tinfoil be used in the oven?
Yes it can,but, it may alter the temperature by reflecting heat which will alter baking times.
Dec 25, 2009 | KitchenAid Kitchen Ranges
I dont know how to set time
Some 70s quartz watches used quite a different system where you push the crown in, hold for a while (perhaps 5-10 sec) then release it and push and hold it back in again immediately. At this point, the ends should set off advancing at many time their normal rate so you can alter the time.
Complex, I know.
Feb 01, 2009 | Bulova Watch
323 people viewed this question
Top TDK Audio Players & Recorders Experts
steve
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
