Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
C
Craig Nichols Posted on Mar 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My electrolux oxygen vacuum wont go and i suspect power supply to the motor or the motor itself
My vacuum cleaner wont go and I suspect the motor or power supply to the motor. how do I get the plastic covers off so as I can get to the motor thanks Craig
deton8 von Splosion
Level 3:
  • Electrolux Master 3,342 Answers
  • Posted on Mar 30, 2014
deton8 von Splosion
Electrolux Master
Level 3:
Answers
3342
Questions
6
Helped
927339
Points
54123
The silver cover is a pressed in panel... (so called "three minute job".. hazardous, quite DEADLY voltages will be UNCOVERED.. use EXTREME caution)
and requires pretty good pressure to get it off... enough where a careless move can damage the cover.
Carefully:
Look at the back of the panel: there are two 1.25 inch (approx) wide slots.
(just imaging a battery flap on a cheap remote controller)
If you can gently introduce a blunt end putty knife into the slot and firmly push it straight forward (toward the hose end (there is a plastic friction tab at each outside end))... with a lifting action you will see the panel start to lift ... you will be able to see the tabs
if you look closely.
Insert your thumbnail on the much stronger corner and pry upward (this requires a lot of force and the corners are the strongest area... breaking the cover is very possible)
Once the silver cover is off you will see the two T20 Torx screws.
Removing them will only loosen the back end... which you should -exercise some caution here... that LED bracket is loose and all the weight is on the wires of the LEDs.
Now set the Vac on in the upright position (nozzle to the ceiling).
Complete release of the top is done by opening the bag compartment and pushing a through the red rectangles in the upper hinge wall. These are latched tabs and will easily lift once the tab is pushed in enough (try not to gough or mar... rememeber it is only plastic).
Both the bag cover and the back cover will lift.
Leave the bag cover and gently negotiate the back cover from inside the handle.
You can now see the big board SUMO (suction motor control board )...
If the glass fuse is not blown... and there are no obvious soot marks...
Take it to the VAC Repair for a free estimate.. They'll tell you it is the hose!!
(which is indeed the biggest failure point of these machines).
Hose slip rings can be inspected <dust & lint>and cleaned (PLUS ruined... Highly likely if you don't get the contacts back in their respective slots) by one screw on the wand end... or three screws on the control/handle end (inside tool carrier recess).
2answers
How do I reset my Electrolux Oxygen Z7320 vacuum , it started cutting out so i replaced bag and cleaned filter now it wont go , both sbag and power lights are illuminated. Any help would be amazing.
https://www.weeklytools.com/category/vacuum-cleaner/
With the growth of technology, vacuum cleaners' importance to keep your beloved home clean is endless. A machine can be disabled. But there is a solution. Following a few simple steps will help you to repair a damaged vacuum cleaner at home. So, Let's discuss Vacuum Cleaner Repair. If your vacuum can't work like before,
Electrolux el7020a brush motor wont run
take the cleaner apart and make sure that the wires are all hooked to the on and off switch that got to the beater bar that is the main part of the problem improper wireing
Need user manual Electrolux 1572F
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Electrolux model by clicking the link below.
https://www.searspartsdirect.com/partsdirect/user-manuals/EL7020A-ELECTROLUX-VACUUM-manual
You can purchase a wide variety of high quality Electrolux replacement parts for your Electrolux vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Electrolux
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
2answers
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
1helpful
My vacuum cleaner is giving off a burning metal smell from the motor when it is turned on.
Looks like ur filter is already blocked and needs to clean up! Check also the dirts going through the motor, sometimes those dirts inhibits air going and cooling the motor itself!
Hope that helps u out!
1helpful
2answers
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
I'm looking for an electrolux oxygen repair manual
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
5helpful
2answers
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Need source for Electrolux Oxygen parts!
Some parts can be found here: http://www.vacuums24x7.com/elox3ulcocav.html
Unfortunately they don't have the part I need.
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
