Question about Samsonite Silhouette 11 Hardside Spinner
I forgot my 3 combination lock numbers. How do i reset my numbers?
How do i reset the lock combination numbers? I forgot my previous lock combination numbers.
2 Suggested Answers
SOURCE: forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Posted on Dec 10, 2009
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
How do i open my tsa 007 lock , i forgot my combination
I agree with the previous answer, and can only add that if something is jammed in there, you'll have to find a way to relieve the pressure on the mechanism while you are trying to move the piece that unlocks it. Depending on what is jammed and where, you may have to press down, up, in, out, or sideways while unlocking it.
Feb 13, 2015 | Locks & Locksmithing
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
I previously set my combination and it worked fine. Now my combination will not work on my cal pak lock luggage. how can I open now and reset combination?
Try rotating the numbers on the combination dial three times to clear any previous entry (stop on the zero's if this applies) and enter your combination one more time to see if this works and gets it open.
The default is 000; to set it, hold the lock open, move the dials to your numbers, and close/open three times. This will set the combination to your numbers.
Aug 27, 2011 | Locks & Locksmithing
How to reset a password on vizio p42hdtv10a tv i forgot the passwored
Hello
To change password use the number pad and type '0000' or whatever password you have changed it to previously, then press OK.
Actual proceedings are:
[1] Press the MENU button to open the main
On Screen Display (OSD) menu.
[2] Press the [
three times until the Parental Control
menu opens.
[3] Press the [Down] button on the remote control
to highlight Parental Lock Enable. The
"Key-In Access Code" window opens.
[4] Use the number pad to type the default
password (0000) or whatever password
press OK.
[5] Press the [Down] button on the remote control
to highlight Access Code Edit.
[6] Press the [=>] button on the remote control
to enter the submenu. You will need to
use the number pad to type default (or
what you changed to previously) password
first
[7] Use the number pad to type the new
password.
[8] Confirm the new password by retyping it.
[9] Press EXIT button on the remote control immediately to exit the OSD menu
Jul 29, 2011 | Televison & Video
I have the combination, but I forgot the order that it is supposed to be applied. IE do I start by turning left or right? How many times? then for the next number in the oposite direction, how many...
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about your Sentry Safe at www.SentrySafeShop.com
Dec 11, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
Get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Feb 21, 2009 | Hardware & Accessories
Samsonite Silhouette 11 Hardside Spinner Logo
60 people viewed this question
Top Samsonite Luggage & Travel Experts
ray gallant
Jerry Kramer
Jerry Kramer
Are you a Samsonite Luggage and Travel Expert? Answer questions, earn points and help others
