Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
My electrolux oxygen vacuum wont go
How do i remove the plastic covers to allow access to the motor to test it as the vacuum wont go when pluged in.I have a multimeter to test mote when i can get to it thanks Craig
  • JoeVacs Mar 31, 2014
    I wouldn't recommend opening it as you will likely never get it put back together again. On the other hand it will not likely need re-assembly anyway as the PC board is probably the fault. I have done 3 of these so far and all of them had bad boards. The PC board is very costly and pretty much makes the machine useless when it goes. The way you get it apart is by first taking the mesh side pieces loose. You will see how to procede once they are off. I warn you though, the plastic tabs that hold it together will most likely break as you take it apart
reddevil6
  • 1673 Answers
SOURCE: Electrolux Epic overheating
It stays closed until the temp. is excedded, then opens. Does the motor shaft turn easily or does it drag. If it drags, then that is what is causing the heat problem. Not sure what it should read, it could be bad, but it should read low ohmns, so it is hard to say.
Posted on Apr 24, 2008
  • 4 Answers
SOURCE: electrolux oxygen vacuum
WARNING WARNING Danger danger Will Robinson! The power head "wand" and the hose from the body of the vacuum have shorts in them. While my wife was using this machine.. she started smelling plastic.. seeing whitish smoke and then sparks... The pin connector arc'd through the plastic... Some research on Google found that this has been a large problem for Electrolux, when i tried to call the factory.. robots.... no solution. Then I contacted a distributor and they informed me that it was not really that big of a problem. Only later to say, that they had replaced ALOT of them. My unit was past its warranty period so I just hardwired it. (now the unit is only two pieces, body and hose w/wand.)
Posted on Nov 07, 2009
SOURCE: electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Posted on Nov 09, 2009
SOURCE: how to remove the motor cover?
There are 2 screw under the removable outlet cover and 2 more under the shiny label under the booster slider. Pick off the label to find them.
Posted on Dec 06, 2009
  • 694 Answers
SOURCE: How do I gain access
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Posted on Sep 12, 2010
How to replace an electrolux 6500 epic motor
To get to the motor you will need to remove the top cover. Take the rubber cover off each side of the vacuum to reveal the piece of plastic that is holding the top and bottom together. Pull the plastic piece on each side out to slide it out, remove the top so you can get to the motor.
Jan 22, 2018 | Electrolux Vacuums
My electrolux oxygen vacuum wont go and i suspect power supply to the motor or the motor itself
The silver cover is a pressed in panel... (so called "three minute job".. hazardous, quite DEADLY voltages will be UNCOVERED.. use EXTREME caution)
and requires pretty good pressure to get it off... enough where a careless move can damage the cover.
Carefully:
Look at the back of the panel: there are two 1.25 inch (approx) wide slots.
(just imaging a battery flap on a cheap remote controller)
If you can gently introduce a blunt end putty knife into the slot and firmly push it straight forward (toward the hose end (there is a plastic friction tab at each outside end))... with a lifting action you will see the panel start to lift ... you will be able to see the tabs
if you look closely.
Insert your thumbnail on the much stronger corner and pry upward (this requires a lot of force and the corners are the strongest area... breaking the cover is very possible)
Once the silver cover is off you will see the two T20 Torx screws.
Removing them will only loosen the back end... which you should -exercise some caution here... that LED bracket is loose and all the weight is on the wires of the LEDs.
Now set the Vac on in the upright position (nozzle to the ceiling).
Complete release of the top is done by opening the bag compartment and pushing a through the red rectangles in the upper hinge wall. These are latched tabs and will easily lift once the tab is pushed in enough (try not to gough or mar... rememeber it is only plastic).
Both the bag cover and the back cover will lift.
Leave the bag cover and gently negotiate the back cover from inside the handle.
You can now see the big board SUMO (suction motor control board )...
If the glass fuse is not blown... and there are no obvious soot marks...
Take it to the VAC Repair for a free estimate.. They'll tell you it is the hose!!
(which is indeed the biggest failure point of these machines).
Hose slip rings can be inspected <dust & lint>and cleaned (PLUS ruined... Highly likely if you don't get the contacts back in their respective slots) by one screw on the wand end... or three screws on the control/handle end (inside tool carrier recess).
Mar 30, 2014 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux ZUA3820P vacuum cleaner - how to access motor for repair
Tricky but you need to lift the slider cover off that adjust Min & Max speed and you will find 2 screws underneath, then you need to slowly take of plactic cover around the inlet hose and you will find another 2 screws
Apr 11, 2012 | Electrolux Vacuums
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
Jan 05, 2011 | Electrolux Vacuums
Vacuum was working fine now it won't even turn on
Did the vacuum just stop dead while you were using it? The vacuum contains a thermal-fuse which will cut the power off if it gets too hot. Unplug it and leave to cool for 10-20 minutes and then try it again.
If the vacuum has already been allowed to cool and there is no power, there are many possible faults including the power switch, motor and thermal fuse. In order to determine where the fault is, you will need an ohm-meter / multi-meter.
If you've allowed the vacuum to cool and it's still dead, please post back for further assistance and let me know whether you have any electrical test equipment.
Regards,
BElectric
Dec 09, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I'm looking for an electrolux oxygen repair manual
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
How is the motor cover removed?
Two screws at the front, accessed by opening the dust bag lid. Two screws at the rear accessed by prising off the on/off switch and rewind button covers.
Jan 05, 2010 | Electrolux Vacuums
How to remove the motor cover?
Dec 05, 2009 | Electrolux Vacuums
Electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Sep 01, 2009 | Electrolux Vacuums
Can't remove motor cover for electrolux EL2050
usually there are screws on the bottom, normally 6-12 screws. Once they are out, there may tabs on the outside of the base fram, lightly use two flat head screw drivers and pull the cover away from the base.. be gentle as this plastic is thin, and could break. You will also need to make sure that the handle assembly is in the down position as the cover can get caught up in the handle when you try to remove it.
Jan 20, 2009 | Electrolux Vacuums
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
79 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
