Question about Kodak EasyShare Z700 Digital Camera
Where to change image resolution on Kodak 2700
Some of the photographs are 1.00mb and yet other are 1.50 or larger - how can I make them to read 1.50 or larger most of the time? Is it to do with image settings and how do I change the image settings to the highest resolution on the camera?
Change camera resolution
Most digital cameras will allow you to select the resolution at which it captures images and/or videos. Some call it "resolution" while some call it "image size" or other similar terms.
The higher the resolution or larger the image size, the larger the file. Many online services restrict the maximum size of image and/or video files they accept. Lowering the resolution or reducing the image size will reduce the size of the files.
Please refer to your camera's documentation. If you still need assistance, please reply to this post and specify the make and model of your camera.
Aug 29, 2012 | Computers & Internet
The HANNSPREE monitor that I just bought is great except for one thing. As a photographer, the HANNSPREE screen is too wide in relation to the normal photograph sizes. The horizontal linear distortion...
The best way to adjust the screen is to adjust the screen resolution until you get a correctly proportioned image.
First display an image such as a square or a circle on the screen.
Go to Control panel - Display - Settings tab and start with 1024 X 768 screen resolution adjustment
click Apply and the check your image.
Repeat the adjust screen resolution select the next highest screen resolution setting, repeat thia process until you get the best image.
Jan 24, 2011 | Computers & Internet
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
MP-80 240 Watts Juicer: where do i go to find a larger image of this parti...
Larger image as in an image of all of the parts, or just a photograph?
I have access the the Ownes Manual if required.
May 18, 2010 | Braun MP-80 240 Watts Juicer
Why does the FinePix E510 pictures download from the camera at 72 dpi when the camera was set to take 500 megapixel photos? I cannot find any way to adjust this in the finepix manual or in online help. I...
A couple of things - I don't think you mean 500 megapixels (that is a lot!) but I assume you mean you expected a high resolution image. You may have it! The dpi setting is largely irrelevant (for photographers) as it simply relates number of pixels to a (notional) print size. Thus an image that is 3000 pixels wide (say) would print out to 10 inches at 300 dpi (3000/300) or 40 inches (approx) at 72 dpi (3000/72). the image has the same information /resolution - it's just "spread" further on the larger print. You can easily change the nominal dpi in e.g. Photshop Elements but it won't affect your image quality.
If however you are getting low resolution images when setting the camera differently that's something different. I would need extra info to help there but pssibly check if the camera was set to RAW and maybe you were looking at the (small) JPEG usually saved with it?
Jun 27, 2009 | Fuji Finepix S5800 Digital Camera
How do you put format the camera to take the highest resolution pictures?
Since you did not state your camera make/model, it is still safe to say that you would need to go into the menu and change the image quality to "large". Typically a JPG if you are not familiar with "RAW" (i.e., if your camera will shoot RAW). JPG is the easiest. The larger the image the higher the resolution. This allows more information to be in your image file. Prints made from larger images will look better.
May 01, 2009 | Cameras
SHOW ME HOW TO START LONG START EXPOSURE ?
The camera conducting a pre-photographing and a main-photographing for conducting a displaying-at-long-time-exposure, the displaying-at-long-time-exposure is continued still after main-photographing starts.
Since the displaying a pre-taken image and the renewing the predicted images thereafter start from the time point, at which a release button is full-pressed, a user can confirm the predicted images in almost real time during the long-time-exposure is conducted
Unfortunately Kodak Easy Share C643 is not capaistated for this purpose.
Was this helpful?
Apr 07, 2009 | Kodak EasyShare C643 Digital Camera
Canon Rebel EOS - Pictures download read Low Resolution
Canon Digital Rebel cameras let you set the image resolution from small jpegs (low resolution) to large jpegs (high resolution) to RAW (best quality, but require post-processing in your computer before you can print them). It's possible that as you were getting to know your camera you accidentally set the image size and quality to a low setting. Now you just need to change it back!
You make this change in the on-screen menu, under the camera menu (first menu, with a camera icon), first item (Quality). Although Canon no longer has the manual for this camera online, you can see This Review Page for more details on where to change this setting on your camera.
Dec 18, 2008 | Canon Digital Rebel / EOS-300D Digital...
I have just got this 22'lcd Samsung 225ms. I cannot seam to fix the problem of blurry letters. This can be very hard to read even at a distance. I have searched for updates online for my nvidia g force...
This monitor will only have a sharp image at a resolution of 1680 x 1050. Any lower setting will result in blurry images.
In an LCD the pixels are fixed, and using any resolution lower than the optimal will cause blurry images. This is called Image Scaling:
http://en.wikipedia.org/wiki/Image_scaling
If that resolution causes the icons to be too small, you can change the DPI setting to 120 from 96, that will make them larger
Jun 09, 2008 | Computers & Internet
Resolution of Stiil Photographs.
the resolutiion dpi has little to do with the camera, its more about printing/displaying - that is just the screen display resolution. you can change that to 300 PPI (DPI) in most imaging applications. the important thing is the pixels you have length and width so 1000 pixels x 1000 pixels is the key to this whats the max pixels of the camera - that would give you the resolution. now to print an image onto paper the acceoted standard for top quality is 300 PPI so 1000 pixels width divided by 300 pixels per inch ppi = 3.3 so you can print at 3.3 inches. Now you may even be able to get away with as low as 180 PPI on some prints and depending on how far away it will be viewed - so this needs to be played with. - can you reply here - with a comment and tell us 1) how many pixels you have 2) what image editing software you are using 3) how big you would like to print
Apr 17, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Kodak EasyShare Z700 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
