No power 10 months used about 5 times
    Top Expert:
  • Televison & ... Master
  • 74,858 Answers
Check and replace the damaged component/s at its main power regulator board, or replace the board as card basis.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 30, 2014
I just got an unregistered sim on my main screen.this phone is on a monthly safelink plan.whats up
Power down. Remove battery, remove SIM, reinsert SIM, reinsert battery and power up. If it is still the same, phone your carrier. Could anybody have got your phone and tried 10 times to guess your passcode? That will lock it and erase everything on it including SIM.
Mar 20, 2016 | Cell Phones
Tip
HELLO TUNE TRICK FOR AIRTEL( legal)
<b>hi Guys...<br />im 1st tym posting mah Trick Which im using from Last 2 months...<br />THIS TRICK HELPFUL FOR THOSE WHO MAINTAIN LOW BALANCE ON PHONE (LESS THAN 10/-)<br /><br />WITH THE HELP OF THIS TRICK U CAN USE HELLO TUNE FOR 10 DAYS @RS 5 ONLY...<br /><br />Now trick is here...<br />.<br />Keep balance app. To zero.. keep balance rs 1 or less than 2...<br />Now call 578785 (toll free) and acticate ur Favorite Hello Tune...<br />after activating.. Ur balance goes to minus 5 (-5)..<br />Dats it...<br />UR HELLO TUNE WILL BE ACTIVATE FOR 10 DAYS... (15 + 10 for just 5 rs.)<br />NOW RECHARGE.. Airtel wont charge u anything later...<br />..<br />.<br />now when ur 10 days are going to over Reduce ur Balance to 1 or less Than 2..<br />Keep ur balance low untill Ur Hello Tune subrcription renew..<br />After 10 days airtel again do ur balance to -5 and renew ur hello tune for 10 days...<br /><br /><img src="smile.gif" /><br />Thats the 100% legal trick.. Working 100% in delhi...<br />Im using it for last 2 months...<br />Enjoy...<br />And reply if its working in ur state or not.??<br />Hit thanx for my work...</b>
on Jan 29, 2011 | Cell Phones
I cannot get my thermostat althc014 to turn down by its self when room tempreature is reached
How To
Set The Temperature
The reason the stat is coming on during the night/ always
being on is setting number 5, there are 5 settings on the Salus
is the time you want heating on eg, 07.00 and set the temp (20)
is the time you want it to go off eg, 10.00 and set the temp (10 this
will turn it off)
3 is the time to come on an evening eg. 17.00
4 is the time you want it to go off eg,
23.00 and set the temp (10 this will turn it off)
5 the problem
many people have is that they do not set number 5 correctly, this is a
night/ frost stat and if you don't set the time and temperature same as 4
ie, 23.00 and 10*c then the heating will stay on.
How To Set The Time and Date On Salus Programmer?
1.Press the
Set and Select buttons simultaneously to enter the clock setting mode.
2. By using
the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock.
Once selected press "SELECT".
3.The "HOUR"
will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the
desired time. Press "SELECT".
4.With the
"MINUTES" now flashing adjust with the arrow keys to the correct
minutes. Press "SELECT".
5.Now the
"YEAR" will need adjusting. Again use the arrow keys to change and press
"SELECT".
6.Now adjust
the "MONTH" with the arrow keys and press "SELECT"
7.Next to
change will be the "DAY OF THE MONTH" again with the arrow keys change
and press "SELECT"
8."dLS" will
now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF"
use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Hope this information is what you need to operate your unit.
Oct 01, 2013 | Computers & Internet
Toshiba Satellite A205-S4707 Boot time is to long need help
you may need a fresh install of the OS, maybe upgrade the ram to 2-3gb, or the worst case factory discs for series model laptop.
Oct 19, 2012 | Toshiba Satellite A205-S4707 Notebook
How to set time on the TIMEX t309t
Please follow these instructions:
Setting the Clock
1. Press and hold the 5 Time Set Button until the display begins flashing.
2. Press the 10 Reverse or 14 Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display.
3. After setting the time, press the 15 Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode.
Setting the Calendar
1. It is important to set the correct date in order to use the 7-5-2 Alarm settings. Press and hold the 6 Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display.
2. Press the 10 Reverse or 14 Forward Button to set the correct year, and then press the 15 Enter Button. The unit will beep and the display will show the month and day. Again, press the 10 Reverse or 14 Forward Button to set the current date.
3. After setting the date, press the 15 Enter Button or wait ten seconds to return to the normal display mode.
I hope I could help.
Thanks
Nov 26, 2011 | Timex T309TT Clock Radio
How i can loose tummy
Hello Dear
If you really want to loose your tummy, do the following easy exersise (if You are not asthamic) any one
1. Climb Stairs 10 to 15 times a day. Start with 5 times then increase it by 2 times daily that is
1st Day= 5 times
2nd day= 7 times
3rd Day= 9 times ..... and so on. till day 10. Increase it to 20 times a day and then stop increasing vut continueing your exercise. In 35 days You will feel the difference in your tummy.
2. Cycling: Lay down straight on your back with your hands under your head. And in air use your legs like you are cycling in air... Start this with 5 mins daily and proceed it to 20 mins daily.
It will take you a month and you will feel your tummy loose as faster as any other procedure or machine using exercise.
Note: Exercise 2 is proved by 10 other peoples. It is Granteed.
If you like my Solution please rate it.
best wishes
Mar 03, 2011 | Healthometer Health o meter Body Fat...
Panasonic TH50PX85U power shuts off and won't come on.
power board failure, common in this model, replace power pcb then check VS and VA voltage could be X or Y driver causing power pcb to fail.
Aug 09, 2009 | Televison & Video
The green power light on my Canon BJC80 flashes and will not stop. I have not used it in MONTHS so clearly the ink cartridge is dry. Is there any link to the flashing light and the out of ink status?
try this
Indicates Waste Ink Full error
To repair follow the steps below
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Jun 26, 2009 | Canon BJC 80 InkJet Printer
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
