Question about Sony RMYD028 Remote Control
Sap Where is sap function
4 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: SAP change with no remote
The set is definately in the SAP mode, which will have some channels in spanish and some channels with no sound at all. You might be able to get an inexpenxive universal remote and go through the menu to return the audio setting to stereo, but if that does not work then you can order an original Sony remote by model number from Union Electronics at 800-648-6657.
Posted on Jul 08, 2007
SOURCE: auto-sap stuck on tv
I unplugged the tivo box and then plugged it back in.  This restarted it and cleared the problem.
Posted on May 11, 2008
toolkits
  • 1099 Answers
SOURCE: NO VOLUME. CAN'T CHANGE THE SAP SETTING WITH THE ...
hello,
First check that any muting control is not activated. This might be a button on the remote or set itself. If you have a headphone jack, it may have dirty contacts as plugging in a headphone usually mutes the speaker.
If the set is mono or only one channel of a stereo set is out, then check for bad connections to the loudspeaker. Test the loudspeaker by disconnecting one of the wires (with the power off!) and measuring its resistance with an ohmmeter (it should be less than 100 ohms - probably less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker terminals - you should get a click or pop from the speaker.
Next, trace back from the speaker output terminals to the circuit board and look for bad solder connections or a loose or dirty connector.
If these tests do not reveal anything, you probably need a scope (or audio signal tracer) and schematic. Or at least the part number off of the chip. Is the final amp a chip also or just a transistor? Have you tested the transistor? If there is little or no buzz from the speaker, that would indicate a problem fairly near the output. If the tuner/if were bad, I would expect some noise/hum pickup from the low level audio stages. Get the part number off of the chip. If it is in a socket, check the contacts for corrosion or looseness.
Good luck...
Posted on May 23, 2010
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
Tip
Cycle SAP function to restore sound on CBS channels
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
on Sep 22, 2009 | Panasonic TH58PX600U 58 in. Plasma HDTV
Some of my channels are in sap and I don't have an audio option on my menu nor the orignal tv remote. How do I change it?
Sorry the SAP function are only can be change in the Audio option menu or the tv original remote only that have the SAP button.Try website like Remotes.com to buy the tv original remote.
Apr 19, 2011 | iLO IWT3206 TV
Where is the sap button on the remote or tv screen?
There would not be a SAP button on newer tv's. You will need to access your TV's main menu, go under Audio or Sound options and search through till you find the "language" or special features area. If your tv has the SAP function, you will find it in the menu.
Jan 18, 2011 | Televison & Video
How do I use the sap function
SAP button,function button is a dupping to audio to spanish langauge for a show.The SAP function only work,if the beginning of the tv show,have SAP logo,when the show begin.
Sep 17, 2010 | Samsung LN37A530 37 in. LCD HDTV
I have no volume on channels 2 and 7. All other
Your SAP audio function is on. Look on your remote or in the TV menu for SAP or MTS. There are 3 settings, Mono, Stereo, and SAP... set it to Stereo. I hope this was helpful, best wishes.
Mar 28, 2010 | Toshiba 32A33 32" TV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
My tv is on spanish how do i take it off
Spanish on the screen or Spanish through the speakers on some channels? If its the on-screen display that's in Spanish, you pick the language using the setup menu with the remote control. If you're getting Spanish through the speakers, you probably have turned on the SAP (second audio program) function. In some areas with a large enough population, SAP is often used to broadcast program audio in a different language. On channels with no SAP broadcast you don't hear any problems. The SAP function is usually controlled by a button on the remote and probably got pressed by accident.
Dec 01, 2008 | Hitachi 51F500 51" Rear Projection...
SAP
There might be a SAP button on the remote or under a cover on the remote, or it might be an audio button, you want Main or Stereo. I couldnt pull up a picture of the remote, but I would suspect that if the SAP function is not in the menu it is probably on the remote.
Jul 08, 2007 | Akai LCT3201AD 32 in. LCD Television
Sony RMYD028 Remote Control Logo
10 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
