Question about Fujitsu fi-6130 duplex scanner
Us sensor who can i open the us sensor panel
Replacing Vizio IR sensor
the sensor can only be replaced by removing the rear panel and then there are two screws that secure the IR board to the front bezel. Takes about 10 minutes from beginning to end very easy replacement.
Jul 07, 2012 | Vizio Televison & Video
Tip
Easy fix for the turn off on the HZ-709 oilded radiator
Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
let's find out how to fix that annoying turn off..
tool needed, a phillip screw driver.. electrical tape or soldering unit..
fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
disabling the sensor
2 ways you can do this..
-you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
or
- you can solder them together on the back of sensor panel...
there you go problem solved...
on Mar 25, 2008 | Honeywell HZ-709 Oil Filled Radiator...
Instrument Panel Codes??
Yes, it's called a lamp fault code.
9 is not familiar to me. Call dealer service department and ask them what code means.
Here are codes for a 94 Aerostar. I don't have 91 Sable. Sorry.
Air Bag Diagnostic Monitor Diagnostic Trouble Code Priority Table Diagnostic Trouble Code Component/Fault Description — No Air Bag Indicator — Inoperative Indicator Circuit or No Battery Positive Voltage to Air Bag Diagnostic Monitor — Continuous Air Bag Indicator — Air Bag Diagnostic Monitor Disconnected or Inoperative 12 Low Battery Voltage 13 Air Bag Module or RH Cowl Side Panel Air Bag Sensor Circuit Shorted to Ground 21 LH Cowl Side Panel Air Bag Sensor Not Mounted to Vehicle Properly 22 LH Cowl Side Panel Air Bag Sensor Circuit Shorted to Battery Voltage 23 LH Cowl Side Panel Air Bag Sensor Circuit Input Feed/Return Circuit Open 24 LH Cowl Side Panel Air Bag Sensor Diagnostic Circuit Open or Low Resistance in Center Air Bag or Front Air Bag 32 Driver Side Air Bag Circuit High Resistance or Open 33 Passenger Side Air Bag Circuit High Resistance or Open 34 Driver Side Air Bag Circuit Low Resistance or Shorted 35 Passenger Side Air Bag Circuit Low Resistance or Shorted 41 Center Radiator and RH Cowl Side Panel Air Bag Sensor Circuits High Resistance or Open 44 RH Cowl Side Panel Air Bag Sensor Not Mounted to Vehicle Properly 45 Center Air Bag Sensor Not Mounted to Vehicle Properly 46 Open Splice Center Air Bag Sensor Ground Monitor 51 Air Bag Diagnostic Monitor Internal Thermal Fuse Blown and Short to Ground No Longer Exists 52 Backup Power Supply Voltage Boost Fault 53 Sensor Circuits Resistance to Ground or Internal Air Bag Diagnostic Monitor Fault — Rapid Continuous Flashing of Air Bag Indicator
Feb 25, 2009 | 1992 Mercury Sable
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Panel reads "water sensor opened"
I had the same problem. The water sensor is on a pipe running into your pump. It will have a circular clamp around it. Remove the clamp and pull the sensor out of the pipe. The wires should run into your control box. disconnect the wires and replace. My water sensor was part 7790. Not sure if you have the same one. Do an online search. bestbuypoolsupply.com has them for $50 plus 9 for shippng. Hope this helps.
Feb 01, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdf
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
Dec 26, 2008 | GE Security Simon 3 Wireless Home Security...
Kenmore 2.1 cu. ft Washer water won't stop filing, cycle doesn't start...
most likely cause
kenmore pressure sensors work off a tube that runs from the bottom of the drum to the sensor, either the tube has come off the sensor body inside the control panel
  • open control panel reattach tube, wrap wiretie or twisttie to keep in plpace
or less likely cause
kenmore level sensors fail
there is a spring inside that stretches over time and mis reads, it is adjustable
  • control panel is still open from previous check
  • remove level selector from control panel, usually an unlock latch on the right side, rotate 45deg counter clockwise withdraw.
  • there is a 1/8 inch bolt head, turn right raise water level, turl left lower water level
Aug 23, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
TV sensor
yes... the sensor is located at the front panel of the TV, but before you get the sensor need to open first the back cover of your unit... after you open the unit please take a picture and upload here to see where is sensor located... the sensor is located in inside of the front panel!
Thanks!
Jul 17, 2008 | Televison & Video
or
Nov 07, 2007 | Honeywell HZ-709 Oil Filled Radiator...
Fujitsu fi-6130 duplex scanner Logo
22 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
