Question about HP PSC 1510 All-In-One InkJet Printer
Everything I scan has two vertical lines and lots of horizontal
The alignment and test page print fine but scanning and printing out is covered with large portions of the page black and multiple horizontal black lines of various sizes.
It all started when replacing print cartridges I tried to align printheads but when I put the printed page in the scanner it said it can't align because the wrong document is in the scanner.
  • lshumway Jun 29, 2009
    Thanks, but I've already done all the recommended steps you can find online. I only use HP products and have tried two different cartridges with the same results.
    The answer I need will have to come from someone who has seen and corrected this problem. Thanks for you advice.
    Guru:
  • 224 Answers
OK Im warning you before hand this is an old out of warranty printer for hp and there may be some hardware malfunction so i would request you to call hp at 18004746836 and simply ask for an upgrade but heres something that you can try for troubleshooting(copy and paste this link in the address bar of your web browser):
Number 1 troubleshooting Link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00307511&cc=us&lc=en&dlc=en&product=428800
Number 2 troubleshooting Link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00308545&jumpid=ot_recdoc/c00307511/en_us/c00308545/loc:1&custom_solutionid=rd_c00307511&lc=en&dlc=en&cc=us&product=428800
Lastly I hope your not using refilled cartridges cauz that causes the malfunctioning of the hardware of the printer
Posted on Jun 16, 2009
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
Iasked for help with a printing problem, The reply to my email address on 5 Sept 2012 to richardborley@yahoo.co.uk got deleted before use. Could Lexmark resend
Please update your printer firmware http://bit.ly/t7sPJR.
Please scan and email us a test page Press the Setup button > Maintenance > Print Test Page. ) from your printer after the update so we can evaluate the result. Please email it to LxkListens@Lexmark.com.
Sep 06, 2012 | Lexmark S405 Interpret All-in-One Color...
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
How do you stop a test page from printing every time the printer is turned on?
Welcome to FixYa!
Here's how to stop the unwanted print out of test pages.
1. Let the printer print the test page.
2. Place the printed test page in the scanner face down and wait for 10 seconds.
3. Press the scan button of the printer to scan the printed test page.
Make sure that the printer scanned the document properly.
That's it. Every time you install a new cartridge, the printer aligns the print cartridge as well as testing/aligning the scanner.
Note: Try to look at the top of the test page, it should have instructions to place it in the scanner.
I hope that this will help.
Thank you for using FixYa.
Jas247
Mar 07, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have an hp 3150 all in one printer. Every time I turn it on to print a document it prints a test page. I am out of color ink so it doesn't print the additional numbers and lines to align the printer. I...
I know your problem and i want to know that have you changed or refill your cartridge?.
if yes
place one plain paper in the tray.
it will print the test paper
print it and place it on the scanner with the printed side down.
press the scan button from the printer
printer will blink the light for some time and stop blinking
now it didn't print test print every time you print
thanks
Jun 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
Each time I activate computer it prints out a test page
With a lot of the all in one printers they want to scan the test page aftert printing to check the alignment. Next time it prints out a page, if a dialogue box appears saying scan now with the option of scan or cancel, select scan. If a dialogue box does not appear, check the menu on the software and look for alignment. That should fix it.
Jan 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
Scanning Problems
I need some more information are the lines horizontal or vertical? Does it print fine from the computer? Does this problem only happen when you scan an item in and then print it or copying an item then print it? Also when you get this output do you have some of the text and lines or just lines?
Jan 08, 2008 | HP LaserJet 3050 All-In-One Printer
My printer keeps printing the test page every time it's switched on
0.gif Re: HP PSC 1513 all in one by Bert t.gif (9/25/07 1:07 PM) reply + / - http://h10025.www1.hp.com
0.gif Re: Re: HP PSC 1513 all in one test page always pr by Anonymous (12/12/07 6:14 AM) reply + / - Subject : How to disable the test page that always prints when you switch on the HP PSC 1513 all-in-one printer.
Take the test page ( also called : alighnment page ) that always prints when you switch on the printer and place it face down in the scanner.
Then press the scan button on the printer itself.
(this is the button at the bottom of all the buttons on the printer/scanner.)
Make sure that the printer scans the test page.
( sometimes you press the butoon and it doesn't scan )
( it makes a scanning noise when scanning succesfully )
Then it will stop printing the test page ( alignment page ) ever again.
This is a really stupid product feature on HP's part to waste ink and force people to buy more cartriges.
beukes2@gmail.com
Nov 29, 2007 | Office Equipment & Supplies
HP PSC 1510 All-In-One InkJet Printer Logo
222 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
