Question about Mueller Adjustable Ankle Stabilizer
Does it work with flat foot
Hurts if i stand alot of time
What are the effective shin splints stretches?
Here are some of the effective shin splints stretches:
1) In a kneeling position, point your toes out behind and gently sit back on your heels pressing the tops of the feet towards the ground.
2) Standing arm length from a wall, put your hands on the wall while keeping your feet and knees straight, then lean forward as far as possible.
3) Standing with your feet flat, bend your knees forward as far as possible keeping your heels on the floor.
4) Put feet flat on the ground and have a partner hold them down. Partner applies resistance to your toes and you lift them up against the pressure.
5) Sitting with your left ankle on right knee, apply pressure to inside of your foot (near big toe) with hand, then and turn your foot up and in, using the leg muscles.
6) In the same position as above, put pressure to the outside of the foot (near little toe) with your hand, and turn foot down and out using the leg muscles.
7) In the same position as above, put pressure to the top of foot (near toes) with your hand, and lift the foot using leg muscles. Repeat these with the right ankle on the left knee.
8) Sit on a table or chair attach a weight (a bucket filled with stones or sand works well) around the foot. Without bending your knee move your foot up and down from the ankle - Start light and work up.
9) Attach one end of a stretching exercise elastic band to the leg of a table or sofa and loop it around the end of the foot. Move your foot up and down and side to side against the bands resistance. Try to draw the letters of the alphabet in the air with your big toe.
10) Stand erect and raise up and down onto your toes several times. You can make it harder by doing it while standing on a step and allowing your calves to stretch over the edge of the step.
11) While sitting lower and raise your feet with the heels on the ground as high and quickly as possible for 60 seconds. This is a great one to do during work days while sitting at your desk.
Sep 15, 2015 | The Health & Beauty
What can I do if it hurts instep side area a photo sent
Try flat bottom shoes with no arch in them. I'm flat footed and have had the same issue before.
Feb 20, 2015 | Miscellaneous
How do you lift a 1982 yamaha 920 virago to the center stand
Left hand on handlebar grip, right hand on handle under the seat, right foot on the centerstand lever, bike vertical on flat ground with the handlebars/front tire straight. Push down on the foot lever of the stand while lifting from the handle. Most of the work done is by pushing the lever and the lift handle is mostly for stabilizing and helping to raise the bike. This applies to all bikes and once you get the feel for it you'll find that any size bike is pretty easy to put on the stand. I can center stand my CBR1100XX while on the bike, first time was hard, but once I got it down it's fairly easy.
Apr 05, 2014 | 2000 Yamaha XJ 900 S Diversion
Tevion19" TV/DVD Combo
Go to a Walmart or other appliance store where alot of TVs are sold
Jan 13, 2013 | Televison & Video
I am having alot of trouble finding info for my white e-6354this is a vintage machine I realize but I can't get the top thread to pick up the bobbin thread
Rethread your machine, making sure your needle is not bent or dull, and please make sure that your presser foot is not sitting flat against the needle plate. Make sure you thread needle with flat side behind and the more rounded side facing you.
Lift the presser foot so that it will open the tension disks.
I hope this helps.
Jimmy
Apr 01, 2012 | White Sewing Sewing Machines
Need the table top stand for a 50" LG flat screen.
U nean like a cabinet with a flat table top?Yes?Tries bricks and molders stores first like ur local furnitures stores or big boxes stores like KIA,if u can assemble things,Big Lot! or Walmart.Tries websites like Amazon.com,Ebay.com to buy.But this is a big,bulky and heavy item.Might get free shipping or not shipping charges could be alots.
Sep 06, 2011 | LG Televison & Video
I have pain (not unbearbale) on my both feet especailly when I get up in the morning. After some time it gets better. What is the reason? I am 62 years. Is it age related? Thanks abraham
You have Plantar Fasciitis. I leave a link with more information.
Plantar fasciitis is most often seen in middle-aged men and women, but can be found in all age groups. Plantar fasciitis is diagnosed with the classic symptoms of pain well localized over the heel area of the bottom of the foot. Often the pain from plantar fasciitis is most severe when you first stand on your feet in the morning. Pain often subsides quite quickly, but then returns after prolonged standing or walking.
http://orthopedics.about.com/od/footankle/a/fasciitis.htm
May 03, 2011 | Quicksilver Medicine Shoes for Men
We've had a new fridge delivered, the Daewoo frsu20iai, how long do we need to leave the fridge standing before switching it on? Different people have told us different times ranging from 1 hour to 24...
ideally leave it for 24 hours(but it wont hurt if you switch it on staight away)the standing time is to allow any air(gas) in the system to rise to the top of the pipes.besides it gives you time to check and level the doors,so that the seals fit flat all round.dont forget to cover/wrap all food in the fridge to cut down on condensation.root veg is best kept in airtight bags.
Aug 06, 2010 | Daewoo Refrigerators
My scale keeps giving me an err2 message. How do
1. Take out the battery
2. Put scale on hard surface
3. Stand on scale for five seconds
4. Put battery back in
5. Tap your foot on scale to make 00000 appear
6. When the 00000 disappear tap your foot on scale again and then stand on scale till your weight appears
If this does not work the first time (it has always worked the first time with my scale) the repeat the steps a second time. If the second time does not work call the company because something else is wrong.
Dec 16, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Error message
Try this, I have the same problem and I just got off the phone with Taylor, this is what they told me to do and my scale is now working again.
1. take the battery out.
2. put the scale on a flat, hard surface
3. stand on the scale for 10 seconds
4. put the battery back in, be careful not to touch any buttons or turn the scale on
5. put the scale back on the flat, hard surface
6. put one foot on the scale and apply pressure until the display comes on
7. take your foot off of the scale
8. wait for the the display to go blank
9. now stand on the scale to weigh yourself.
This worked for me. Hope that it works for all of you.
Dec 29, 2008 | Taylor Dgtl Body Fat Scale
Mueller Adjustable Ankle Stabilizer Logo
Top Mueller Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Mueller Health and Beauty Expert? Answer questions, earn points and help others
