Question about Brother XR7700
I've taken it apart to thoroughly clean and fix problems, but stupidly forgot to label my screws.
I just need someone with some experience taking this model apart and putting it back together to tell me which screw goes where.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Brother Expert
  • 300 Answers
You could come over to my house, I'll help you. But your Brother repair shop is probably closer...
Posted on May 14, 2014
2 Suggested Answers
PeterTweeter
SOURCE: I need to take apart
XR-52 (and probably similar) has 9 screws on the back and bottom that needto be undone - be sure to keep track of which screw goes where becausethey're almost all different. One other screw is under the "nose" piece which holds the front shell to the back - it just needs to be loosened. After you haveremoved the 9 screws and loosened the one I mentioned you start at the bottom and pry apart carefully of course, noticing that the last part comes apart at the top where the three wheels go thru the back shell. In order to take off the front shell you need to remove two more screws, also fairly obvious. Reassembly is opposite order being sure when you get ready to put the back on that you align the three wheels at the top first, then work down to the bottom, replacing all the screws. That's really it - not rocked science. Just be sure not to over-tighten screws going into plastic. Have fun!
Posted on Aug 05, 2012
My Sapphire Viking sewing machine says thread under stitch plate. I have taken it apart and cannot find any thread or lint. What can I do?
Check that there are no thread pieces, lint, etc. anywhere around the bobbin area. Sometimes, things get pulled into the mechanism where it isn't seen or a sensor has a speck of dust that is interfering. If a thorough cleaning doesn't resolve the issue, it may be time for a service call.
Nov 12, 2016 | Sewing Machines
The whole square holding the needle fell, how can I fix it ?
Sounds like the screw/screws holding the driver in place have came out. Unfortunately, it will need to be taken somewhat apart to tell. I'm pretty sure you will need to take it to a sewing machine repair shot or at the least a small engine repair shop. We could never get into the small space to repair our own machines.
Feb 25, 2016 | Sewing Machines
Bobbin case catching thread
I believe that you are talking about the assembly that holds the bobbin case in. The bracket that holds the bobbin case in must be adjusted to allow the upper thread to slide by. Check if the thread will go by this area without "hanging up" while rotating the hand wheel. Also check your bobbin to make sure you have the right one. If it is too high or wide it will definitely be a problem.
Apr 17, 2017 | Janome SEW MINI Mechanical Sewing Machine
Sewing machine's bottom part won't move ;(
If your machine just came up this problem and it was sewing just fine before hand, then I would suggest that the part that makes the bottom move has gotten bent at some point. You may not be able to see the bend but that might be something to look into, and you may have to take it into someone to have it repaired. There should be a dealer or sewing store in canada that can honor the warranty.
Oct 14, 2012 | Brother PC-420
Bobbin case knocking on stylist 7258
Sounds like the timing is off, bribean01. I just fixed mine. It wasn't hard, but taking the machine apart, finding the right screws to loosen, set the timing and figure out how to put it all back together again was not easy. It's been days of work. I took it apart three times. I have an extra screw left over (you know that's not good). Singer did not make this easy to fix. There is a complicated metal casing around the parts you would be attempting to reach from one angle while needing to have a grip from another. Several sets of eyes would be helpful, too-if only!. It will require english and metric allen wrenches several screwdrivers pivotable lighting...My point is- you can do it, but in retrospect, it probably would have been better to spend $125 to let someone else to do it- someone who can then be blamed. When my machine jammed I also broke a tiny piece off the rim of the bobbin case. I was hoping it wouldn't matter, but it catches the thread, so...i'll order the $15 part and use the time to consider how badly I need to take apart the machine again to find the hole that is missing a screw. Good luck Gals!
Jul 19, 2012 | Sewing Machines
Shuttle alignment and assembly
The shuttle/race/bobbin system shouldn't really be taken apart by the average user. Unfortunately, your chances of ever getting it back together properly so the machine will sew (this is the timing of the machine) are very slim. You'll need to take it to a sewing machine technician. I would recommend an authorized Pfaff tech as they'll be sure to have the proper tools to do this correctly - won't be inexpensive but will be worth it. Most "neighborhood sewing machine repair folks" don't have experience on computer machines. Resetting timing on a computer machine isn't the same as the old mechanicals and requires some expertise.
May 02, 2008 | PfaFF Creative 7570
Bobbin thread not able to feed itself to top thread
Number of possible causes. First thing I would check is the timing, impossible to describe how to do it, sorry I cannot help anymore
Mar 20, 2007 | Singer 2662
Brother XR7700 Logo
85 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
