Question about HP Deskjet 1510 Allinone Inkjet Printer Copyprintscan
Printer not printing
String not found message comes
Printer will not print to the margin
What kind of printer? The print string may need to be manually entered. Try going into the properties section of the print screen dialog. You should find a box there to enter the parameters of your print string.
Dec 22, 2012 | Office Equipment & Supplies
Error 3802 comes up. Tried switching off and re-starting. Menu comes up ok but when I try & print or copy, error message re-appears! Help
Found the answer to the problem on the Kodak support site.
Changed the black print cartridge.
Thanks for your help anyway...........
Feb 04, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
After downloading the disc for my cannon mp500 I try to open the cd label print and a message comes up with "a compatible printer for printing cd media was not found"
please you are frist time instoll a printer driver cd ?
if yes then second time this driver cd is not excepted. beacose you this cd is out of your pc. and this message is not coming.
Oct 10, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Cannot print and fax using Lexmark x2470 All-inOne Center
Make sure your printer is set up correctly, check port it's set to be using, is it usb or lpt port. Try switching to a different port and see if it will help you.
If all fails, try deleting the printer and associated devices from device manager. Reconnect the printer, if a new hardware found message dons't come up, try a different USB port. I think, in order to successfuly install a PNP printer, it must first come up a message saying NEW HARDWARE FOUND. Then the rest will follow.
Aug 21, 2009 | Lexmark X2470 All-In-One InkJet Printer
Canon MP620 Wireless All-In-One can't print to it
Hi
I had exactly the same problem. Here is how I solved it.
I deleted all the previously installed items (although this might not actually be necessary). Then I re-installed using the 'Easy Instal' option from the CD.
The CRUCIAL part is this: - after you have tested your connection to the printer - and it is all fine - another box should appear with a MAC address for the Scan Twain. Highlight the string of numbers and click APPLY.
THEN THE MOST IMPORTANT BIT - look at page 54 in the set-up guide. And follow the instructions which are:
When the printer utility opens click ADD - then go to 'more printers' select the MP620 with the string of numbers after it. This is the one you want NOT the one that appears automatically when you complete the installation.
make this printer your default and away you go! That should work as it has for me and i have been pulling my hair out on this for about 3 weeks!
Dec 28, 2008 | Canon MP610 Photo All-In-One Printer
I have an iP-1600 Pixma printer. I have replaced both ink cartridges and the printer does print; however, the box still comes up saying "printer ink is low; replace cartridge." How do I get rid of this...
I think you are using 40/41 or 830/831 cartridge sets. Ink cartridge 41 are now a days found defective, even if it has original company mark. Tell your vendor to replace it with genuine one. Neglect the message "ink volume low". Try to print in gray scale mode avoid colour printing.At least you will be able to get your documents printed.
Sep 03, 2008 | Canon PIXMA iP1600 Printer
Blinking E / 3 - string fell in the paper feed and jammed. Now what?
To reset MP 150
1,power off, hold stop/reset ,power on;
2,hold power,release stop/reset, push stop/reset twice;
3,wait untill Led show "0",push stop/reset four times;
4,push power twice.
finish
Aug 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Back door closed
I did not get any error message but the 6940 printer would not print. Instead "Ready" the printer said "door open". When I deleted printer and plugged the usb cable back in the XP machine found the new hardware, said "Ready" and could print.
Dec 22, 2007 | HP Deskjet 6940 InkJet Printer
Printer is printing code from webpages I am trying to print
Steps:
Start-> Control Panel-> printers and faxes/printers/devices and printer.
Do right-click on printer icon and select properties.
Click on Advanced tab.
Select the option "print directly to printer" and click on Apply and Ok.
Then try to print , hope it works.
Jan 09, 2007 | Brother MFC 420CN All-In-One InkJet...
HP Deskjet 1510 Allinone Inkjet Printer Copyprintscan Logo
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
