Question about Janome Sewing Machines
Material will not feed
When sewing the material does not feed in
  • Janome Master
  • 1,388 Answers
Check under needle plate for lint holding feeddogs down
Posted on Apr 22, 2014
  • 323 Answers
SOURCE: material will not feed across
This machine has a pressure regulator on the left side.You should look to see that it is not loosened. When you lift up on the presser foot it should have resistance.
Then look at the feed dogs to see that they are moving, Set the stitch length at 4 and turn the hand wheel. The teeth should move towards the back of the machine. They should also be slightly above the needle plate as they go back and below the surface of the plate as they come forward.
If they don't rise above the plate , remove the needle plate and clean between the slots of the teeth.
sewman7
Posted on Jul 01, 2008
RickE1
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
SOURCE: will not feed material or sew
Before you take it to a repair shop make sure that your one step buttonhole lever has not been moved by mistake. That happened to me just yesterday. If your machine keeps sewing in reverse all the time that could be your problem. It happened when I was going over all the parts in my sewing class. Although material was feeding through but everything was sewing in reverse. Check that out and make sure your buttonhole lever (#14) on the diagram is pushed up. I don't know if that is your problem but it is something you can try.
Posted on May 28, 2009
Zenqi
  • 208 Answers
SOURCE: started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Posted on Nov 14, 2009
  • 96 Answers
SOURCE: Sears Kenmore Sewing machine model wont feed
you need repair service for that one
Posted on Dec 13, 2009
Janome Machine will not feed material !!
If the fabric is not feeding, the feed dogs are probably not operating properly. Check that they have not been dropped below the needle plate (which is done when darning or free motion quilting). In this setting, the feed dogs never rise above the needle plate to grab and pull the fabric.
The other issue could be that the feed dogs are defective or perhaps seized.
Since you did not provide a model, I can provide only this assistance. It would be helpful to locate (search for make model manual) for your machine.
Dec 30, 2016 | Janome Sewing Machines
Manual for brother vx757 free please
A manual feed is used primarily in freehand embroidery, quilting, and shoe repair. With manual feed, the stitch length and direction is controlled entirely by the motion of the material being sewn. Frequently some form of hoop or stabilizing material is used with fabric to keep the material under proper tension and aid in moving it around. Most household machines can be set for manual feed by disengaging the drop feed dogs. Most industrial machines can not be used for manual feed without actually removing the feed dogs.
Nov 19, 2013 | Singer 8280 Mechanical Sewing Machine
When i start to sew my presser foot is not moving at all and all thread i think accumulate at the back of cloth .. please help
The presser foot should only glide over the material. The feed dogs move the material. Check to see if your machine has a drop feed feature... for embroidery... or darning, etc. If it does return the feeds to sewing position.
Sep 24, 2013 | Sewing Machines
When i start sewing sometimes the material gets sucked down into the feeds dogs. this causes the thread and the material to make a mess i sometimes can not get the thread out i am making quilt pieces
Use a scrap of fabric under the pressure foot as a leader and feed the quilt square after it clears just like if you are chain sewing. After you have sewn the square clip the scrap off and use it again.
Feb 09, 2013 | Brother LS-1217 Mechanical Sewing Machine
White model 445 material won't feed?????
Hi Jason. I wonder if you have your feed dogs lowered. It's near the bobbin area.
Here's a pdf of your manual. It talks about "drop feed" on book page 19
Good luck
Nov 16, 2012 | White Sewing Sewing Machines
Machine won't feed material. I have to pull while sewing.
First of all stop pulling that will only bend your needle and cause further problems.
Check to make sure your feed dogs are engaged. There should be a switch somewhere around the sewing area front or back or perhaps under a flat bed attachment.
Oct 28, 2012 | Singer 4423 Sewing Machine
Singer 507 sewing machine - material wont feed through
if the fabric won't feed thru then there is something wrong with the feed dogs
May 25, 2012 | Singer Sewing Machines
The feed dog will not advance the material
Call Singer at 1-800-4singer and they will help you. I think a piece of the needle may be stuck in your feed dog
Oct 11, 2009 | Singer 3116 Simple
Material won't pull through feed
you need feed teeth Pulling at a height of 1mm and you need pressure from a presser foot on the top. Check these
Mar 17, 2009 | Sewing Machines
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
22 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
