Question about AOC Televison & Video
Turn on subtitles tv
There is no provision for subtitles on AOC LED tv
Power led brightly on but no display on AOC S5G10
It is understood that your AOC monitor is not working, you had followed troubleshooting steps like connecting VGA and Power cable from monitor to computer and the monitor panel light is ON but still no display. You have tried connecting another monitor and it is working fine, so it is advised to contact AOC support to check if the monitor is under warranty and it can be replaced or repair. To help you do these, please follow the link given below:
http://us.aoc.com/aoc-technical-support/?page=contact-technical-support
GuruAid.com
May 24, 2016 | AOC Computers & Internet
My aoc l24h898 lcd tv led light turns blue but then turns red in seconds
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 17, 2015 | AOC L24H898 24 in. LCD TV
I have a 32 inch Upstar LED TV. How do I turn off closed captioning?
On the remote there is a button for Subtitles. Press that button and the Subtitles will disappear. If it is not on the remote then you have to find it in the TV's settings. 'Closed captions' are old words. We now call these 'Subtitles' and all TV's with remotes have a 'Subtitle' button. Look for it, then press while pointing the remote to the TV.
Dec 28, 2014 | Upstar Televison & Video
REMOTE doesn't work on AOC L22W898
Change your batteries. Clean the battery contacts. Use a digital camera pointed at the LED on the remote to see if it is working. It might actually be the TV, but it is usually the remote.
Jan 10, 2014 | AOC L22W898 22 in. LCD TV
LED on front panel blinks on/off endlessly. Set won't turn on and buttons do nothing.
You probably have a power supply problem. The electrolytic capacitors are a high failure item in these TVs. I just replaced two capacitors in the power supplies of my two AOC TVs and got both of them working again. Repair will probably be much cheaper than replacing the TV. The capacitors will only cost a few dollars. The labor will be the greatest expense.
Aug 17, 2013 | AOC L42H861 42 in. LCD TV
My Sony Bravia KDL40HX800 led tv plays divx videos but cannot read external subtitles, they dont even appear when I open my usb connected on the tv. Please tell me which steps should I follow so as to...
If you already name the subtitle file (.srt) with the same name of movie file (avi, mpeg, mkv etc) all you have to do is press green button on the remote control the turn on/off the subtitle. It works for me.
Jan 22, 2011 | Sony BRAVIA KDL-40V3000 Television
My new 24" AOC LED
The problem may be your computer, plug a spare monitor in the desktop, if you see the same issue, it is the Video Graphics Card in the computer that is causing the problem. However if it turns out the spare monitor is fine, it is your new monitor that has the issues and should be returned for exchange.
Jan 06, 2011 | AOC Monitor
How do you turn off subtitles, I have turned off, but every time I change channel it reset to on again? Model L32HA91
I know you may have sorted this by now, but this question is everywhere for this tv, I solved it
Same directions as before,
Menu-Features-subtitles, THEN CHOOSE 1ST SUBTITLE,
scroll through languages, until you reach OFF
also turn off analogue subtitles, cures it.
hope that helps
tozol
crankygamersuk.net
Dec 18, 2010 | AOC Televison & Video
Remote fOR AOC LCD L37W781B won't work
try to replace a crystal capasitor on your remote
Feb 21, 2009 | AOC A15X221 15 in. LCD Television
Televison & Video Logo
14 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Jayesh Panchal
Jayesh Panchal
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
