Question about Lenovo ThinkPad R60 Notebook
My IBM Lenovo R60 with Windows XP3 shows blue screen all of a sudden and restarts Pls help NS Rana
  • 7 more comments
  • NS Rana
    NS Rana Mar 31, 2014
    Hi !
  • NS Rana
    NS Rana Apr 12, 2014
    I could not get any solution from this forum. Here is the video clip demonstrating the blue screen.https://www.youtube.com/watch?v=M0sf3ASA...
  • darkstorm357
    darkstorm357 Apr 12, 2014
    hi, i can send you a software for your drivers to be install and update, but can you try to lower you resolution first, and observed if the blue screen will still appear don't open any other programs just observe it...thanks
  • darkstorm357
    i'd seeen the video...
  • NS Rana
    In the mean time I have tried to remove RAM, cleaned it with alcohal, inserted it again but no change. pls send the software at narpat007@yahoo.com. I am trying to do what you have suggested and will update
  • NS Rana
    NS Rana Apr 13, 2014
    Hi ! I have changed the resolution of the display to 800x600 (medium 16 bit) after this I have powered on and off the machine 4-5 times and I have not seen the blue screen till now. This means there is issue with display driver. But originally the display driver for Lenovo R60 machine was downloaded from Lenovo web site. Pls suggest as I can not continue to used low resolution display.
  • darkstorm357
    darkstorm357 Apr 14, 2014
    you can view the type of display adapter on your computer by typing "dxdiag" on the search box and hit enter, at least you know which driver you have to download. thanks
  • NS Rana
    NS Rana Apr 15, 2014
    Hi ! I have run dxdiag and unable to upload the generated txt file. Its quite large, pasting the entire text here may look odd to there members.
  • NS Rana
    Pasting here some text related to display; Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.120821-1629) Language: English (Regional Setting: English) System Manufacturer: LENOVO System Model: 9457A75 BIOS: Phoenix FirstBIOS(tm) Notebook Pro Version 2.0 for ThinkPad Processor: Genuine Intel(R) CPU T2300 @ 1.66GHz (2 CPUs) Memory: 1526MB RAM Page File: 1041MB used, 1858MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.5512 32bit Unicode. ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: Mobile Intel(R) 945 Express Chipset Family Manufacturer: Intel Corporation Chip type: Intel(R) GMA 950 DAC type: Internal Device Key: Enum\PCI\VEN_8086&DEV_27A2&SUBSYS_201A17AA&REV_03 Display Memory: 224.0 MB Current Mode: 1024 x 768 (16 bit) (50Hz) Monitor: Default Monitor Monitor Max Res: Driver Name: igxprd32.dll Driver Version: 6.14.0010.4926 (English) DDI Version: 9 (or higher) Driver Attributes: Final Retail Driver Date/Size: 2/15/2008 13:12:06, 57344 bytes WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: igxpmp32.sys Mini VDD Date: 2/15/2008 13:12:06, 5854752 bytes Device Identifier: {D7B78E66-64E2-11CF-2467-1000A2C2CB35} Vendor ID: 0x8086 Device ID: 0x27A2 SubSys ID: 0x201A17AA Revision ID: 0x0003 Revision ID: 0x0003 Video Accel: Deinterlace Caps: n/a Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Not Available DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Its a blank blue screen or with a error message?
please mention the full details.
thanks
Posted on Mar 30, 2014
Testimonial: "Hi ! Thanks for supporting. It's blue screen with some HEX address location, I have not noted it down as I do not know when the blue screen will happen. This may happen any time. Regards NS Rana"
  • 28 more comments
  • NS Rana
  • NS Rana
    This blue screen may happen soon after the first power on of the machine and may not ahhen for few hours and then happen suddenly or may not happen some day.
  • darkstorm357
    darkstorm357 Mar 31, 2014
    hi Rana, this are system crashes bu
  • darkstorm357
    sorry about that...this are system crashes but we don't know from where, it may be from hardware or from recently installed software. to check this, you have to boot your computer unde safe mode, by hitting F8 upon the restart till you get a black page with repair options. just use arrows to choose from this options and hit enter to select. just choose safe mode and let it boot till windows page will come out. fyi..it is normal that not all your system function will work under safe mode. after windows has been fully loaded, click start and in search box type "problems & solution". on here we can view all crashes history on your computer and their detailed cause. by then, we know where we'll start. pleasse note the crashes that oftenly happens.
  • NS Rana
    Hi ! Thanks for your support. I just going to do that, will update soon.
  • darkstorm357
    thank you, i'll wait for your update....
  • NS Rana
    Started in safe mode, tried to search "Problems & Solution" but did not find anything. Mine is Windows XP, SP3. Today, around a couple of hours back, I had blue screen and then the machine restarted soon. I could only see "Stop: 00000050" zeros may be more or less. Could it be of some use to you to analyse ?
  • darkstorm357
    hi, thank you for the info, the code that you provide is an error code for conflicts uprade of your OS to your display adapter.
  • darkstorm357
    once again, boot up on safe mode locate the device manager. to locate device manager on xp. just click start then click run, and type "devmgmt.msc" on the run window command.another will pop up with all your hardware on board. try to locate display adapter and click the arrow beside to drop down the installed driver. right click this driver and click uninstall. finish the unintallation and close everything. then restart your computer in normal mode.
  • NS Rana
    Okay, just doing that, pls be online..will update quickly
  • NS Rana
    Hi ! I just finished doing that and on normal restart, I got login screen. I loged in and then suddenly there was blue screen with message "Stop: 00000050" and then it restarted.
  • darkstorm357
    if you can give me a screen shot or image of the device manager window in safe mode, it will be great. or add me on skype "mhanzpanget" for a fast reply. last option we could to do is to take out 1 memory at a time. to see if it is faulty or not.
  • NS Rana
    NS Rana Apr 09, 2014
    Hi Pls find attached the screenshots as you suggested. I was in countryside for quite some time, sorry for delay.
  • darkstorm357
    darkstorm357 Apr 09, 2014
    Hi, Rana,
  • darkstorm357
    Hi, Rana,
  • darkstorm357
    please send your email add, i will be sending a software to your for drivers, extract in on usb or external harddrive and run to this computer under safe mode. thank you for your patience.
  • NS Rana
    Hi ! my mail id is narpat007@yahoo.com
  • NS Rana
    The blue screen comes with error message on the top "Fault in Non Paged Area" and in the bottom there is 0x0000050. Zeros in the left to 50 may be more or less, I could not count.
  • NS Rana
    Today, I have recorded a small clip of the blue screen.
  • darkstorm357
    Hi, I can send you a software to install and update your drivers. but can you lower your resolution and see if the blue screen will still appear? icons will be in biggers size but just to diagnose your system. thanks
  • NS Rana
    Hi ! I have changed the resolution of the display to 800x600 (medium 16 bit) after this I have powered on and off the machine 4-5 times and I have not seen the blue screen till now. This means there is issue with display driver. But originally the display driver for Lenovo R60 machine was downloaded from Lenovo web site. Today I just fresh downloaded the display driver of Lenovo R60 machine from Lenovo site, installed it, restarted the PC. I observed the blue screen when I repeated to power cycle the machine 3rd time. Pls suggest as I can not continue to used low resolution display.
  • darkstorm357
    Hi, you can download the video driver from the link provided below. Please ensure that you had download the chipset driver first before you download the graphics driver with the right OS and bit (32 or 64 bit).
  • darkstorm357
    http://www.fixya.com/support/p564502-len...
  • darkstorm357
    sorry..this is thhttp://support.lenovo.com/en_US/research/hints-or-tips/detail.page?&LegacyDocID=MIGR-64283e right link...
  • darkstorm357
    http://support.lenovo.com/en_US/research...
  • darkstorm357
    please let me know if this will be a fix or not..thanks
  • NS Rana
    NS Rana Apr 14, 2014
    Hi ! My machine is ThinkPad R60 (9457-A75). From the site you have given link for, I have already downloaded the respective chipset driver and display driver and installed. But still when I change the display resolution from 32bit to 16bit, then I do not observed the blue screen after many many restarts but if I keep the resolution to 32 bit then I get blue screen very frequent. Could it be due to some hard disk problem ?
  • darkstorm357
    we're not sure, but as per your diagnose it only comes from your adapter. if hard disk failed even in 16 bit you'll have the blue screen. i supposed to send you the software for drivers but i can't, coz it quite big. if you can download the
  • darkstorm357
    "Driver pack solution" software you wil able to install all your drivers even without net.
  • NS Rana
    My problem is not resolved
boylaptop
  • 62 Answers
SOURCE: IBM Lenovo R60 Freezes after i turn it on for a
Processor and video chip overheating, they have the same heatsink and maybe needs new thermal paste.
Posted on Apr 05, 2010
  • 13 Answers
SOURCE: lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Posted on Mar 19, 2009
TampaNative
  • 778 Answers
SOURCE: sound device problem
Just go to IBM's support site and download the latest drivers for your machine, and use those (the ones with the most current date by them).
Good luck.
Posted on Feb 24, 2008
rhojojoe
  • 93 Answers
SOURCE: I WANT AN AUDIO DRIVER FOR IBM LENOVO R60 TAPE
Ibm lenovo r60 tape 9458 mq8 audio driver download it from here: http://www.gzrcw.net/drivers/IBM/IBM/drivers_1004.html
Posted on Jun 15, 2010
  • 794 Answers
SOURCE: My Lenovo Thinkpad SL 400
Hi kingston_koa,
Getting different colors with vertical strips are common effects of broken LCD/screen. Broken LCDs needed to be replaced. With this one, the best thing that I can recommend you is to contact Lenovo specially if your machine is still under warranty. They offer free repair and parts replacement depending on your warranty coverage.
Hope this will help you.
Thank you for using Fixya.
Posted on Feb 28, 2011
Why does my Lenovo Thinkpad R60 keep rebooting safe mode then blue screen
You probably have a corrupt windows file. Try F8 before it tries to beet and select recover system or restore.
Jul 21, 2014 | Lenovo ThinkPad R60 Notebook
Sound driver
Lenovo ThinkPad R60 PC Notebook sound driver.
For windows Vista, Click on this link http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-67218 ,look for this file 77a324ww.exe and download it. Read and follow the instructions that follow.
For windows XP, click on this link http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-62855, look for this file 77a224ww.exe and download as you follow instructions.
Dec 04, 2010 | Lenovo ThinkPad® R60 PC Notebook
Parity error :only when im playing games, after playing a game 20 minutes (10 if it has good graphics) the computer screen goes blue and it says "Call your hardware vendor for support NMI: Parity check/...
increase ur virtual memory then for high resolution game u should install a graphics card , nvidia graphics card is the good quality card . After doing that plz check
Jun 01, 2009 | IBM Lenovo ThinkPad R60 Notebook
Charger
A new charger costs $15/$40 , if you keep using the one sealed with tape you risk to damage the laptop.
Follow the good advice given by the customer support and get a new charger instead.
You can have the charger repaired for $60 or get a new one for $20:
IBM Lenovo Thinkpad R60 R61 90W New AC Power ...$21.95
Feb 07, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
IBM R60 thinkpad Audio prob
Try to install all the new drivers from this site
http://www-307.ibm.com/pc/support/site.wss/MIGR-64283.html
i think it will solve this problem. Dont forget to install chipset drivers graphics drivers etc..
Thanks
mohan
Oct 18, 2008 | IBM ThinkPad R52 Notebook
Wireless Network Problem - IBM Thinkpad Lenovo R60
FN + F5 is normally starting your radio connection on Lenovo Think pad
Aug 12, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Motherboard
You can download drivers for IBM thinkpad R60 here: http://www-307.ibm.com/pc/support/site.wss/MIGR-64283.html
Hope it helps
cheers
Feb 14, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Lenovo ThinkPad R60 Notebook Logo
95 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
