Question about Brentwood JC-450 Juice Extractor
Remover aspas para limpiarlas
Remover las aspas para limpiarlas
How do I remove the flim carrot stains from the plastic parts
IF THE STAINS ARE ON THE OUTER BODY REMOVE THEM WITH THE NAIL POLISH REMOVER, IT DOES WONDERS.
REGARDS.
PLZ. RATE THIS
Jul 05, 2011 | Breville BJE510 900 Watts Juicer
I purchased a Hamilton Beach juice extractor, Type CJ01, Model 395W from a thrift shop. No manual available. How do I remove the circular blade cup to clean?
The solution i have found is relatively simple, but going to take a bit of handy work.
first, it would greatly help to remove the bottom from the unit. You will need to remove the 4 rubber pads, and then the 4 screws. 2 of the screws are way up there and need a thin philips.
Regardless if you removed the bottom, you will need to drill a hole right in the center of that circular grill on the bottom piece.
If you did NOT remove the bottom piece, I would take a nail, clamp it with vice grips, get it red red hot off the burner, and burn away that center plaster to create a hole. So whether you drilled the hole (with the bottom removed) or burned the hole (with the bottom intact), you will see the bottom of the motor has a slot head.
Now, all you need to do is take a thin blade screwdriver, or thin butter knife into that slot, holds the motor, then twist the blade right off...or on...whichever the case may be.
Hope this helps...sure helped me!
Oct 30, 2010 | Hamilton Beach 67800 HealthSmart Juice...
I don't know how to clean my jack lalanne's power juicer
remove to arm that holds top slide it twards you then use tool to remove blade then remove juicing screen then the bowl (the one that says jacklallanes power juicer
Mar 02, 2010 | Jack Lalanne Power Juicer 250 Watts
Do not know how to remove basket
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
Dec 29, 2009 | Salton JM411 Juiceman II Elite Juicer
Jack lalanne power juicer cresent took problems
Use the orange tool to remove the blade. IF you don't have the tool, just find a big wire around 1/8 diameter thick . Bend it and insert both ends on the blade holes. Cover the sharp blade with cloth or use leather gloves. Turn and remove the blade. The orange filters removes easy.
Aug 18, 2009 | Jack Lalanne Power Juicer 250 Watts
I need the crescent tool and would like to ask barbi1 if she still has one i would like to purchase it from her
Use the orange tool to remove the blade. If you don't have the tool, just find a big wire around 1/8 diameter thick. Bend it and insert both ends on the blade holes. Cover the sharp blade with cloth or use leather gloves. Turn and remove the blade. The orange filters removes easy.
Aug 13, 2009 | Jack Lalanne Power Juicer 250 Watts
How do i get the orange thing off of my power juicer i dont know how you need to help me now!!!
Use the orange tool to remove the blade. I you don't have the tool, just find a big wire around 1/8 diameter. Bend it and insert both ends on the blade holes. Cover the sharp blade with cloth or use leather gloves. Turn and remove the blade. The orange filters removes easy.
Jul 18, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
rhanson616@cox.net
Sep 08, 2008 | Juicers
Jack La Lanne's Juicer
I removed mine by removeing the 3 screws on the blade
and lifting the whole filter out.
Feb 22, 2008 | Jack Lalanne Power Juicer 250 Watts
Brentwood JC-450 Juice Extractor Logo
52 people viewed this question
Top Brentwood Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Brentwood Juicer Expert? Answer questions, earn points and help others
