Question about Kenmore 22422 Top Load Washer
Kenmore 70 series filled and stopped...
I have a Kenmore 70 series washer that has filled, but now will not agitate or drain. Electrical outlet and circuits are functioning properly, but the machine will no longer cycle.
    President:
  • 3,113 Answers
Lid switch problem. Press down on lid and try to start machine. Reply.
Posted on Jun 16, 2009
  • 2 more comments
  • Lance Brandow Sep 21, 2011
    Tried that. Any other suggestions?
  • melanie harriman Oct 08, 2011
    mine is doing the same thing, thought it was the pump, but not that either
  • Mark Lear Jan 06, 2012
    Ours is doing the same, pressed the lid switch down with a ink pin and it starts working again. You have to depress it further than what the pin on the lid does and it will make a slight click noise. Anybody have information about how to replace the switch?
  • chrisclay850
    chrisclay850 Feb 20, 2013
    thank you for this post. Just stuck a screw driver against my lid switch and it agitates and drains immediiately.
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
to answer your first problem,
if it wont stop filling, then the pressure switch is either defective,
or the hose that is attached to the drum to the pressure switch was either pulled out or had an opening either it breaks or it cracks.
that would not transfer the filling mode to agitate mode.
the second problem that it wont drain and spin now is another issue but might be resolve if you solve the first problem.
tnx 4 using fixya,
drcool
Aug 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
1,887 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
