Question about Vacuums
Dyson dc 39
Brand new. The brush stops spinning after a minute or two from starting the machine. Debris gets stuck at the rubber flap in the head and does not pass in the tube. Will trimming that rubber flap to make the debris pass, will it affect its suction power?
  • Vacuums Master
  • 1,296 Answers
If it is brand new, you should take it to a Dyson warranty repair center. They are professionals and know what to look for.
Posted on Apr 02, 2014
ps6666
SOURCE: Our Dyson DC23 turbine head
i have the same baffle prob with 2 heads..was a quick phone call for free replacement...hey jack this is a know prob with baffle plz redesign if u havnt allready dc23..other then the hassle of having to call 1 a year and wait 1 week for parts ..its a good vac..
Posted on Jul 16, 2013
  • 61 Answers
SOURCE: no suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Posted on Jun 03, 2009
reddevil6
  • 1673 Answers
SOURCE: Low suction with Eureka Whirlwind 4481 Upright
Most times it is plugged at the inlet. There 2 screw on top, one on each side, in one of the holes or slots. Take top cover off, then check that inlet and hose to see if it is clogged there or not, you might replace the belt while you have cover off, part# 54312. I am sure it is stretched if it hasn't been replaced in a while. If the hose is clogged, the you will have to take off the handle, then the hose can be taken off so you can clear any clog in it.
Posted on Feb 05, 2008
ukvacfan
  • 328 Answers
SOURCE: spinning debris in cup
If the 2 stage filters inside the bin chamber have not been washed then they will need to be - they sound like they are clogged or somewhere there is dirt which is blocking up the system. Also check the side part duster to ensure that the airways are not clogged with dirt.
When you turn the machine on, have a look to see if the moving brush is actually spinning. Then switch off and remove the base plate to see if anything is clogged in the main dirt channel which is usually located on the left or right hand side - where the dirt goes in from the floor.
This model is based on an Electrolux model in the UK which can be notorious for clogging dust. Check the hoses at the bottom where they come from the main dust bin and the air ways to check no dust is stuck.
Posted on Apr 19, 2008
Dysonteam
  • 167 Answers
SOURCE: the brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 22, 2010
Dyson D28 the brushes will not spin
Start by cleaning all hair and debris from brush roll and nozzle area. If that doesn't solve it you may need a new PCB. If that doesn't solve it you may need a new nozzle assembly.
Mar 13, 2016 | Dyson DC28 Animal Upright Vacuum New DC 28...
Dyson DC23 canister vacuum turbine head stops spinning. Red on/off circle does not start the brush. If we cover the rubber 'u' gasket a tad, it will start spinning again normally. Putting the cover on does...
Hi Jyn, it's Jack at Dyson.
The rotating brush bar in DC23's Turbine head is powered by the vacuum's airflow. From what you've described, it sounds like there may be a blockage somewhere in the machine that's affecting the performance.
To locate and remove any blockages, please take a look at our online Support guide and follow the steps shown on each of the pages: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/check-telescopic-wand-step-1-turbine-head
In normal use the pre-filter should be washed at least once every 3-6 months, using cold water without detergent. Even a filter that appears to be externally clean may still need a wash as fine dust particles may be contained within the filter material. The correct method is shown in the video attached. Make sure you allow the filter to dry completely for at least 24 hours before replacing it.
We would advise against attempting to modify the Turbine head in any way, as this could cause damage not covered under guarantee. If you'd like some further advice from our experts please feel free to give us a call - our contact numbers are: 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 23, 2014 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
Dyson DC23 canister vacuum turbine head attachment stops spinning.
bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
May 17, 2017 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
Dyson dc 24 brush works intermittently
Broken wires in the side of the machine
Dec 27, 2013 | Dyson Vacuums
Dyson brush wont turn
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first.
Oct 08, 2012 | Dyson DC25 All Floors Bagless Upright...
Brushes don't spin
I'm sorry to hear you're having difficulty with the motorised brush head on your DC31 Animal. If the head won't seem to work correctly after you've checked for any obstructions, I'd encourage you to get in touch with us directly as we'd appreciate the opportunity to provide further assistance.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call, as one of our advisors may be able to resolve the issue with some troubleshooting over the phone.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 11, 2012 | Dyson DC31 Animal Bagless Handheld...
Dyson Brush Bar Always Spins
Take off the brush cover and check that the suction orifice is clear. Also check the rubber flaps at the bottom of the hose/handle holder is correctly positioned.
Feb 06, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
