Question about BOSS AUDIO SYSTEMS BV7320 Car Video Player
Boss audio systems BV8972 where is the remote wire
Is there a remote wire on a bv8972
What is error code 76 on a Rheem tankless hot water heater that has propane connection?
Communication Fault with Remote Control. At a minimum check the following: 1. Check remote control wiring for loose or damaged connections. 2. Bypass remote control cable by connecting remote control directly to remote control terminals on PCB. Replace cable if found to be faulty. Yes Either the wiring or the remote control is at fault. To rule out the wiring, disconnect the remote control and use a short, good jumper wire and connect directly to the remote terminal on the PCB. If the unit works using the remote, then the wiring is at fault. If the unit does not work, then the remote is at fault. Did the unit go to main burner? No Replace the Printed Circuit Board Remove remote control wires from wiring terminal on the PCB. Plug unit in and open a hot water source.
Dec 16, 2016 | Rheem Water Heaters
What am i doin wrong with my boss radio? when i set a station when i shut the engine off i loss my settings
Sounds like your Memory +12V wire is not connected properly. If this wire does not have a constant source of power then you will lose all of your settings on your radio.
Things that may cause you to lose power through the Memory 12V wire:
  • Not hooked up properly to the battery
  • Bad battery
  • Bad ground
  • Loose wires
Boss 637UA manual
Sep 04, 2014 | BOSS AUDIO SYSTEMS BOSS 637UA - radio / CD...
Wire remote
cc648301-b75d-43c4-9819-79d9a6303880.gifBlue/red is the power on for amp / antenna.
Aug 25, 2013 | BOSS AUDIO SYSTEMS 612ua
When i plug the remote wire in with the ground and power wire plugged in tight, i'll wiggle the remote wire and the heat and power safe lights flash on, but if i just leave the remote wire in the fan...
try bridging the remote wire to the positive power wire to see if the problem persists, if this cures the problem then you have a problem with your remote wire, check the cable path to see if you have inadvertently put a screw through the wire or if there is any of the plastic wire covering missing.
May 05, 2011 | MTX JackHammer JH600 Car Audio Amplifier
Cant get sound in dvd mode only in radio mode
PS: Check if you car has remote wire or anterna wire.
Details below.
A relatively common problem is installing an amplifier with a factory head unit or other head unit without a remote turn on wire (or a burned out circuit). So the amplifier doesn't stay on 24 hours a day you need a way to turn it on and off remotely. Hence the term "remote turn on wire". Almost every aftermarket head unit has a remote turn on wire. Some manufacturers call it a power antenna wire. But regardless of the label all it does is output a positive 12 volts when the head unit is turned on. It should be noted that some head units have both a remote turn on wire and a power antenna wire. It's important to use the right wire for your amplifier and other electronic equipment. In the case of both remote and antenna wires the power antenna wire will only output 12 volts when the radio is on. If you were to connect your amplifier's remote terminal to the power antenna wire then you would only get output from the amplifier with the radio. When you switch to CD the amplifier would not work because the head unit turns off the power antenna wire when the radio is section is not active.
There are several ways to get your amplifier to turn on and off remotely even if your head unit does not have a remote turn on wire. The cheap and easy way is to run the amplifier's remote terminal off of a switched accessory wire. This is the wire that your head unit uses. It is only powered when the key is in the accessory or run position of the ignition switch. When you shut the car off the wire loses power and the head unit and amplifier will both turn off. Your amp will be on when your car is on and off when you car is off. If you don't want the amplifier to always be on when the car is on you could wire a simple switch inline with this new remote wire. Normally you would leave it on so that it turns on when the head unit is on. But if you wanted to turn the amplifier off you could flip the switch to off which would stop the flow of 12 volts to the amplifier's remote turn on terminal.
Baadaye Mo
Oct 26, 2010 | Clarion VZ709 Car DVD Player
I bought new boss bass600. I presume that I wired everything correctly, but whenever any metal part of RCA cable is touching the input receiver unit (even before plugging all the way in) the red light...
Not wired correctly and there is a short being created when you do what you described. Have someone other than yourself go over the wiring to resolve the issue.
Aug 27, 2017 | Boss AUDIO SYSTEMS BASS600 Car Audio...
I would just like to have the wiring diagram for the Boss AVA 9060 model. Thanks!
wires are: red-ignition, yellow-battery or memory, black-ground, blue-remote for amp or antenna, orange-illumination (if it has one), the white, grey, purple and green wires are the speakers
Sep 17, 2010 | Boss AVA-9060
BOSS AUDIO SYSTEMS BV7320 Car Video Player Logo
70 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
