Question about Konica Minolta DiALTA Di200 Copier
Minolta EP2100 Copier - Error Code C5
Kind assistance would be appreciated to fix my Minolta EP2100 error code C5. I have pressed the black reset button (as sugggested on this site) and was unsuccessful at fixing the error code. I believe that I need to replace either a thermal fuse, heat lamp or thermistor. I would appreciate any help on where to locate these parts in the copier and step-by-step directions on how to replace them. Also any suggestions for where to purchase for the best price would be appreciated. Thanks to anyone who can help.
  • Konica Minolta Master
  • 6,696 Answers
Mite try amozon/craigs list for parts, The machine is legacy system
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 25, 2009
How do i fix error code C-3502 on a konica minolta bizhub500 photocopier
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
Dec 27, 2013 | Konica Minolta bizhub C450P Laser Printer
C163 on b52izhub c5
3B02,3B03,3B04 - IH malfunction.Try reset the error code:
Turn OFF the copier,press and keep pressing the Function key and turn ON the copier.Keep pressed the Function key until appaire the Trouble reset message on the display.Release the Function key ,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Dec 23, 2013 | Konica Minolta Bizhub C452 Copier
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta biz hub c550 error code c-EEE3 Help please
To reset the malfunction code press follow keys:
Turn OFF the copier,press and hold pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message on the display and release the Utility key.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Good luck.
Mar 21, 2013 | Konica Minolta Office Equipment & Supplies
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
How to reset error c0500
The error code means that the fuser is not warming up correctly. There is a small black rest botton on the main controler PCB on the back of the copier. You are going to have to take the back cover off, I believe in is four screws. Turn the power off and remove the back cover and find the small black botton, once you have found it, turn the copier back ON and press the botton and see if the error code can be rest. If it dose you are good to go... If not you may have to replace the fuser unit..... I did have a problem that was not solved with the fuser unit.. It turned out to be right side door switch... I would look there as well with the back cover off... Good Luck
Apr 04, 2012 | Minolta DiALTA Di183 Copier
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Jan 17, 2010 | Minolta Office Equipment & Supplies
Minolta ep 2151 D has C-5 error code
If you look at the fuser heatting lamp and it looks like a cande cane it is blow. You will have to replace the lamp to reset the code. You may also need to change the thermal fuse and or the thirmister as well. They all deal with a c5 error code. If I remember correctly there is a trouble reset botton on the back of the copier, it is on the main controler of the copier it is a small "Black" botton. You will have to take the back covers off to get to it. I believe a c8 has to do with the scanner power cable getting stuck. It has been about ten years since I worked on one. Good Luck
Jan 28, 2009 | Canon imageRUNNER C3220 Color Copier
Minolta EP2030 shuts off immedietly when I power it on
Do you see a error code? Like a C5? Try holding the power botton on and look for a code that shows up on the display. You may have a blown heater lamp or scanning lamp. You are losing your AC power some where.
Jan 22, 2009 | Minolta EP1083 CS/PRO Copier
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
197 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
