Question about Hitachi Televison & Video
HITACHI LCD 32''
THE SOUND CAN BE HEARD BUT PICTURE CANNOT BE SEEN ?? PLEASE HELP
    Top Expert:
  • Hitachi Master
  • 74,383 Answers
Check and replace the back-light inverter board. There is no back-light now. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 30, 2014
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
praky16
  • 744 Answers
SOURCE: Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 07, 2009
ginko
  • 19396 Answers
SOURCE: ViewSonic TV sound but no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
SOURCE: Olevia 32" LCD HD TV model 232-S13
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Posted on Oct 18, 2009
circuitworld
  • 335 Answers
SOURCE: 32'' Vizio LCD no picture or sound
Your filter capacitors have popped due to diodes shorting, P-channel FETs shorting from gate-to-drain. Pull-up resistors have changed value and as a result your capacitors have peaked (popped)....so now the tv is in protection mode to prevent further damage to your tv. Take it to your local shop for servicing, or take it back if its under warranty......
Posted on Nov 05, 2009
Sound quit working
after what incident the sound stopped /
Jan 19, 2008 | Dell W3201C 32 in. LCD Television
Hitachi 32' lcd Tv L32A03A manual guide
SAYA ADA MODEL LCD 32'' HITACHI L32A03A. ON GAMBAR DISPLAY JADI PUTIH. SOUND OK.TRY AV PUN SAMA. TERIMA KASIH
Aug 04, 2012 | Hitachi Televison & Video
When I turn on the tv I get a hissing sound coming from within the unit but no picture is displayed. Sound comes through speakers but that's all I get. I can't seem to find any relevant info regarding the...
It is a bad power supply for the backlight. That is the only section capable of such a noise. Good luck i hope this helps. I know i have heard similar sound from a laptop with similar issues! Prodzilla
Mar 30, 2011 | Hitachi L32H01 32 in. HD-Ready LCD TV
Heard a loud pop during turn on, not picture but
Ur LCD inverter board it dead.Replaced this board u will get ur picture back.Tries websites like shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long shape board.
Apr 26, 2010 | Toshiba 32HL66 32 in. LCD HDTV
We have a 32 in lcd dell tv with sound no picture...
Yes, either a new back light, or a new inverter (the circuit inside the TV that powers the back light): http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120540641447&rvr_id=&crlp=1_263602_263622&UA=WVF%3F&GUID=a4a3861a1240a0aad0b022b0ffee21c3&itemid=120540641447&ff4=263602_263622
It looks like the parts for your TV are readily available online (unusual), but I couldn't find the backlight itself, sorry.
Mar 26, 2010 | Dell W3201C 32 in. LCD Television
Hitachi P50H401 display problem
it is problem your TV high voltage unite(EHT)
change it by authorised service centre
Aug 28, 2009 | Hitachi P50H401 50 in. Plasma HDTV
My Hitachi TV has gone black
Chances are you have either a bad X SUS board, a bad Y-SUS board or bad Power Supply. In the worst case possibly all three.
I a very rare occasions I have seen the Plasma Panel cause on or more of the above boards to fail. The only way to find out is to call a professional to verify. I would not recommend going it alone.
I hope this helps,
Skyassoc
Jul 19, 2009 | Soyo DYLT032C 32 in. LCD Television
Mar 12, 2009 | Televison & Video
Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Mar 11, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
18 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
