Question about Kirby G4 Bagged Upright Vacuum
Change brush indicator light
Replaced brush indicator light on kirby g4 and light still wont come on
  • Kirby Master
  • 1,534 Answers
If the light is not glowing it means the brush roll is not spinning. The belt may be stretched and need replaced. The brush roll may be installed improperly. The magnet in the brush roll has to be aligned with the indicator light for the light to work when. The brush roll is spinning
Posted on Apr 22, 2014
b0sslady2001
  • 357 Answers
SOURCE: kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Posted on Oct 25, 2007
b0sslady2001
  • 357 Answers
SOURCE: Manual and tools kirby g4
The first link is instructions for changing a belt. The second is for the shampooer instructions. If you click on the links below, it will take you to my online guides and if you look there, your other question will be answered. Thanks!!
Marci
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Posted on Nov 09, 2007
  • 4 Answers
SOURCE: No suction on kirby g4 upright vacuum. Can't use attchments.
First remove the mini-emptor and check for a clog also check the fan for anything cloging that or the hose may be clogged
Posted on Jul 10, 2008
b0sslady2001
  • 357 Answers
SOURCE: Motor is making blue sparks.
It's the brushes for sure!!! My switch repair guide will get you down to the carbon brushes easily...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
marci
Posted on Jul 31, 2008
RockyNR1
  • 324 Answers
SOURCE: Sparks from the Kirby Motor
1. Do you think this may be the problem?
YES
2. How come it continues to rotate?
Motor armature consists of multiple coils and just some of them burned so even though it keeps spinning it does not function properly.
3. Do I need to replace the armature?
We have switch replacement instructions HERE and they will take you as far as accessing the motor. We do not have motor assembly instructions yet but if you get that far - motor is not that hard to reassemble. You may have to spend some time getting tolerance ring back in and make sure you install finger spring properly.
Good Luck
Posted on Jan 06, 2009
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
Green light no on
HI There,
When the green lights do not come on when vacuuming with a Kirby, this indicates that your belt2_bing.gif has either broken or fallen off. There is a magnet on the beater bar that activates the LED green light when it's spinning.
Here's a helpful video tutorial2_bing.gif that we recorded, that will show you how to replace the belt, as well as perform basic maintenance on your roller brush to prolong the life of your belt as long as possible.
Video Repair on How To Check The Belt on a Kirby Generation G4:
I hope this was helpful! If you have any follow up questions, please feel free to use the comment field here on Fixya.
If you need to purchase a new roller brush, or belt for your Kirby G4, here are direct links to those parts on our website:
Kirby G4 Roller Brush Assembly:
http://www.govacuum.com/kir108.html
Kirby G4 Agitator Belt:
http://www.govacuum.com/kir143.html
If this repair was helpful to you, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by the Fixya community when someone answers your questions.
Thanks again,
Chris Jones
GoVacuum.com
May 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How do I put the belt on the Kirby the correct way in order for the green light to come on? The green light indicates that the Kirby will pick up.
The G4 has a magnetic block on one end of the brush. It must be aligned on the LED end of the brush housing. ..with adjustment screws facing out. When setting the housing back in place use the pedal to lift the carpet nozzle up off the work surface
Sep 06, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4D belt change . haven't changed the belt in years ! not sure who it goes on, or around the the spool housing ??
Changing belt on Kirby is a bit complicated. Kirby Co. just did not make it easy for their customers. You have to be careful when installing the brush roll back. Brush roll end caps have to be put back a certain way. For detailed instructions with pictures go HERE.
Good Luck,
Rocky
Mar 28, 2009 | Kirby G4 Bagged Upright Vacuum
Good armature maybe needs new brushes
You can replace the carbon brushes and most repair shops should have them. Also tho, the armature could be causing the problem, if you put in new brushs and it still arcs badly, then the armature is bad.
Apr 16, 2008 | Kirby G4 Bagged Upright Vacuum
Replacing brush roller on my KIrby g6 limited edition
You need a new belt. When the green light goes out, that means your brushroll has stopped spinning. Here's how to change it....
Even if you just replaced the belt, this guide will help you make sure that you got the brushroll back in the right way.
Hope it helps....
Marci
Dec 08, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G5 vacuum
Marci
Sep 17, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
111 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
