Question about Ryobi Garden
Dont want to start
Petrol model 4 inch blade
Ozito petrol chainsaw will not start and its new
Make sure you have followed the starting instructions, have filled with correct mix of petrol/gas and oil. If it still won't start, take it back to the retailer.
Jan 18, 2014 | Garden
How long is the band saw blade on model 113.24330C
I can't find a Sears model 113.24330C but there is a 113.243300 so hopfully part of the last 0 got worn off. That model is a 12" bench top band saw that uses a 1/4 X 80-inch blade.
Mar 19, 2012 | Craftsman Saws
Don't if the coil is shooting enough spark back to the plugs?
Remove a plug wire,.the longest one of the 4! Place a flat bladed screw driver down into the plug wire,and into the bottom of the end of the wire.or boot.Hold the screwdriver blade about or at least a 1/4 inch from a good ground. Have some one crank the engine .There needs be a spark 1/4 inch or more long and rather wide spark not thin or narrow, and spreading out where it hits,check this with a good hot battery,not one that doesnt crank the engine good.Every thing turned off not to sap the battery! All other wires should be grounded out with a test lead ,so the engine dont start! Check all 4 the wires may be bad. They can be checked for resistance as well,you need an ohm meter,set on the thousands scale for ohms check and accotding to the wires length! none over 30,000 ohms 10,000 is plenty
Sep 06, 2010 | 1987 Dodge Omni
Need two 7 1/4 inch blades, can I find that in a store or do I have to order it??
You will find a large selection in any decent hardware store. You can also use 7" blades in your saw. the important thing is dont go larger than 7 1/4 and make sure the arbor matches your saw(or has a knock-out that will make it match). It's good to have a selection of different toothed blades on hand for your various projects. For basic construction, any brand of carbide tipped blade is fine, for finer work, my personal preference is Freud (less expensive)or Matsushita (more expensive).
Happy sawing:)
Farmerbear
Aug 30, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
How to change the blade on a craftsman scroll saw? The manual was been misplaced when we moved
You might be able to find the manual on the Sears site (this can be a frustrating search - but start with the model number). But even without the manual, this is pretty easy on most scroll saws. There is usually a plastic knob (about the size of a ketchup bottle lid) on top of the machine at the back. You loosen this knob a couple of turns (to the left) and the blade will become very loose. The blade is probably the "pin-end" type - it will have a little cylinder about a 1/4 inch long on each end of the blade. You can buy new blades at any home improvement or hardware store. Besides qualtiy, the main differences will be the length of the blade and the size of the teeth (expressed as TPI or Teeth Per Inch). You need more TPI for cutting harder and thinnner materials, less TPI for softer and thicker material. Put the new blade in like the old one was (teeth pointing down) and tighten the plastic knob. It's hard to be sure how tight is should be, since it doesn't suddenly tighten up. About a 1/4 turn past where is starts to get noticeably tighter is a reasonable place to start. If the blade pops off during use, it wasn't tight enough.
Jan 14, 2010 | Craftsman 16" Variable Speed Scroll Saw
Straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Craftsman snow blade install instructions
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Dec 14, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Garden Logo
13 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
