Question about Sewing Machines
Sunbeam sb700 how to thread
Little Sunbeam SB1818 sewing machine--we've used it once, was okay. Now, the upper needle won't pull up the bobbin thread--what are we doing wrong?
there is no needle thread tension make sure that the upper thread is between the tension plates and not behind them
Jul 18, 2017 | Sewing Machines
Sunbeam sb700 the thread will not come up from the bobbon when I turn the wheel.
Install a brand new needle and confirm it is installed facing the correct direction. If it still will not pull up the bobbin, the machine may be out of time. Search for sewing machine timing or take it for service.
May 28, 2017 | Sewing Machines
My Sunbeam SB1818 needle will not pick up bobbin thread so I can sew what do I do
make sure tat there about 6" of bobbin thread hanging out after you put the bobbin back in the bobbin holder
increase the needle thread tension up more thread tension should be a slight drag as you pull the thread out to thread the needle
Oct 30, 2016 | Sewing Machines
Can not get thread through the hole in needle holder
Trying to thread the needle holder? You should be threading the upper thread through the needle's eye. If it won't fit, then the thread is too large for the size needle you are using. There are many needle types and sizes, so using the correct needle for the fabric and thread is important.
All About Needles
Feb 17, 2016 | Sunbeam SB1800 Compact Sewing Machine - -
Doesnt stitch
Do you chose the right spool and put it the right side up?
Apr 14, 2014 | Sunbeam SB1800 Compact Sewing Machine - -
Instructions sunbeam
check operation of needle thread tensioner
Feb 03, 2014 | Sewing Machines
Sunbeam Portable sewing machine won't sew
If you definately have it threaded up properly, follow the thread all the way through the route of "threading up"there could easily be a bit which is catching, or try another thread I have found a lot of low quality threads about
Jan 05, 2013 | Sewing Machines
Sewing Machines Logo
178 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
