Question about Samsung Microwave Ovens
Microwave won't stop running
I have a Samsung SMH1816S that will only turn off if unplugged. It did not give me an error code, but if I shut the door it runs, and heats water, even though the light is not on and the turntable is not going. I can use the control panel to set time, and then the light will turn on and the turntable will go, but once it beeps that it is ended, the microwave goes dark but keeps running and heating. The only thing that stops it is opening the door.
    Problem Solver:
  • 16 Answers
There's a ghost in your microwave, call ghost buster. Seriously, the problem is the control panel. (((((the microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. That's more than 30 wall outlets combined.
Replacing electronic parts in a microwave oven can be extremely dangerous.))))))) tank you
Samsung Model SMH1816S XAC Parts
Posted on Mar 30, 2014
MicrowaveSvc
  • 9098 Answers
SOURCE: NN-T990SA Panasonic Microwave Stopped Heating
This model uses an inverter to produce high voltage instead of a convential transformer system. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Posted on Dec 23, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs with door open
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
SOURCE: Panasonic NN-S533WF Microwave
because of high voltage circuit thats happend ,please check highvoltage circuit may be short circuit or any companent burntout. check magnetron and high voltage diodes etc.
Posted on Sep 29, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave turntable won't stop running
This is usually caused by either a bad door switch, but may instead be a loose door switch mount or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 19, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JE1860 microwave won't turn off sometimes
You probably have a sticking relay on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details of our service, plus *critical* safety, disassembly, and troubleshooting info at our site.
You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
It is possible that you might have a bad door switch but I don't think so. In case you or a friend want to check that first, here are some links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
Turns on when door is open; turns off when door is shut.
when mine did that it was the door switch had failed
Jan 21, 2016 | In Microwave Ovens
Mod SMH1816S Shows SE error only 2 yrs old How to fix
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
See my profile picture if you need more help.
Nov 15, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Turns on when door opened
There is an power interlock inside the oven that breaks the power connection to the magnetron when the door is open. Most likely, something is stopping the switch from opening.
Check for a small plastic probe on the door that may have broken off inside the oven keeping the circuit made. Otherwise, open the oven and see is some foreign object is keeping the connection made or if the interlock needs to be cleaned out so it can function.
Jul 11, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Why door will not stay closed
Latch or catch is either broken or misaligned. Find out which and repair or replace.
Aug 10, 2014 | Samsung SMH1816S Stainless Steel...
Samsung SMH1816S suddenly stopped working from fully functional state. A click sound was heard when it went dead. After that no sign of life even with power on. Checked ceramic fuses on noise filter to be...
Repairman just diagnosed mine as a bad display board, it quit working while nobody was even home, and cost $269 with a $70 service fee. The microwave is less than 2 years old and only cost @$400 new. I was lied to by the salesman when I made the purchase (imagine that, a salesman lied to a customer) he told me these were very good and reliable microwaves and that I should get years of service out of it, what a crock... I will never buy another Samsung appliance again, they have many many bad reviews and are made with inferior parts. I will stick with Kenmore kitchen products from now on!!!
Apr 04, 2014 | Samsung SMH1816S Microwave Oven
Overheat turn off
After a quick internet search I found that Samsung has had problems with thier microwaves turning on by them self. I would unplug it till you need to use it and contact samsung or local repair shop about getting it fixed
Mar 14, 2014 | Samsung Microwave Ovens
How to replace fuse on the samsung SMH1816s over the range microwave
no problem with fuse - it is due to lose contact on the panel board - open from the front , most probably their will be lugs which may had come out /lose. .
Jan 10, 2014 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Microwave Ovens Logo
1,084 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
