Question about Panasonic Microwave Ovens
Microwave door will not close
Door will not close
PROBLEM, ROOT CAUSE: the METAL FLANGE holding the fixed latch and (3) interlock safety switches is about a thick as the metal in the screw cap on a glass bottle ... say 16 gauge or less.
The METAL FLANGE is thin, wing that has not support to prevent it from swinging like a door hinge. We use (2) of the microwaves everyday. One has never given the "DOOR CLOSE" will not operate problem. The 2nd microwave worked for two or three years. Then it was difficult to close ... and the panel gave the failure message ... "CLOSE THE DOOR."
I was able to use my thumb to press and remove 'dimples' into the metal. It was giving just a little more support than a 'say 10 vertical sheets of wet white copy paper.' We I bent it back to the proper alignment, the door closed and the switches worked. But after just a few cycles of OPEN & CLOSE, the switches would not let the microwave operate ... and the door began harder to close.
SOLUTION: To prevent or limit the movement of the METAL FLANGE, I used (2) connected loops of cable ties like a vertical suspender. The suspender prevents the METAL FLANGE from moving away from the center of the microwave.
1. Un-plug the power cord.
2. There are two methods to remove the case:
(a.) Turn the microwave on one side, the place a ruler beside one of the TORX (with center security pin) screws. Take a digital photo. Go to an auto parts sales office that sells a license plate kit with a kit (a TORX wrench with a drilled HOLE and many of the same TORX (with center security pin) screws.
(b.) Drill out the center security pin at each of the TORX (with center security pin) screws.
3. I used (2) each 12 inch long plastic cable ties. The width was less than 3/16" wide (so it would thread into two [~0.15 inch diameter] existing ventilation holes in the microwave).
4. I threaded one of the plastic cable ties thru a hole at the top, near the front, about one inch toward the center of the microwave.
5. I threaded the 2nd plastic cable tie thru a hole in the bottom, near the front, about 2" towards the center from the latch plate.
6. I formed a large loop with the bottom cable tie, very loose, do not tightened at this stage. I threaded the open end of the top cable tie thru the bottom cable tie loop.
7. THEN I carefully
(a) opened & closed the DOOR, WHILE
(b) watched the position of the METAL FLANGE
(c) AS I slowly tightened each of the large loops of cable ties.
(d) I repeated steps (a) to (c)
(e) I stopped tightening when the CABLE TIES LOOPS provided SOME support, AND the METAL FLANGE still have some hinge movement.
My Panasonic NN-SN797S door would not close. My solution has worked since about March 1st, 2013. Below is a photo from the factory manual. microwave door will not close - ebd9fdc7-5cb0-4461-ace5-77040f1420eb.jpg
Posted on Apr 20, 2014
Microwave door doesn't close properly.
It's doubtful that it's supposed to work that way. For safety's sake, Id take it in for repair.
Mar 13, 2016 | In Microwave Ovens
Door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Feb 10, 2008 | Emerson MW8987B/W Microwave Oven
When you close the door, the system will not program , on our kenmore microwave oven. Now it trips the breaker. Why?
I am assuming that closing the door is a key to when the problem arises and will usually lead to a faulty door switch(s). The door switch must be made in order for the microwave safety circuit to be completed and let the microwave know that it is safe to operate. Door switch(s) are one repair worth making on a microwave as most other repairs are not worth the cost of the microwave oven. If you are handy you can check to make sure the switches are closing with a multimeter. Please make sure you have unplugged the microwave before attempting to check the switches. You do not need the power on to verify the closing of the door switch(s).
Aug 14, 2014 | Microwave Ovens
I have a panasonic microwave genius protege type AP104A which will not always work after closing the door
Closing the door operates a switch or switches which function as an interlock to prevent the oven from starting unless the door is closed completely. The switch or switches may be defective or misadjusted. Also, the door may not be closing properly to close the switch(es).
Dec 07, 2013 | Panasonic Microwave Ovens
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Dec 26, 2012 | Magic Chef Microwave Ovens
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
I have an nn2505c microwave that powers up but displays door open
Took it to a repair shop ,cannot be fixed ,no parts discontinued microwave.
Jan 19, 2010 | Panasonic NN-2505A Microwave Oven
Door won't close!
Is it the catch or won't the door close fully?
Oct 06, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
