Question about LG HBS-700 Bluetooth Headset
Constantly disconnecting from my phone
While talking....bluetooth disconnects from pnone
2 Suggested Answers
xyver
  • 173 Answers
SOURCE: bluetooth and lg phone randomly connect and disconnect
you can try removing the device and repairing it.
Posted on Oct 02, 2009
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
The light blinks constantly when the headset is switched on and does not connect to the phone
first the turn off bluetooth .... after that switch on the button and dont shoot the but in that time connect with the pnone it will connect.....
Aug 04, 2011 | Nokia BH102 BH102 Bluetooth Headset...
My Plantronics Blue tooth earpiece gives a constant "three beep" sound. I can hear the other person on the phone but the constant beeps at the same time. The beeps happen also when the phone is...
The three beeps usually indicate low talk time. If you have tried turning off and on your headset and still have the annoying beeps, then there is a problem with the device. You'll need to contact your retailer or Plantronics (800-544-4660 x5538) for warranty replacement. If it's out of warranty, check out our website Headsets Direct for the latest in Bluetooth headsets.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a plantronics bluetooth. I'm not sure of the model. After I talk on it sometimes the bluetooth will peep and seems to disconnect from my voyage phone but the bluetooth stays on. I hit the call...
Install Nokia Phoniex in your computer and attach handset.
1. detect device 2. click on device information and print it. you got answer
Jul 01, 2010 | Cell Phones
Hiw do I disconnect my bluetrek from my phone
Just turn your headset off, by holding the Talk button for some 5 seconds. Besides, if your phone's bluetooth radio won't be used for other functions (like e.g. file transfer), turn it off too, in order to save some battery juice.
Just my 2 cents.. Carlos
May 09, 2010 | BlueTrek G2 Consumer Headset
While my Motorola H700 Bluetooth is in my ear, it will automatically disconnect and then reconnect over and over again. WHY?! And HOW DO I MAKE IT STOP?!
I should have looked before posting my problem--but I skimmed through others posted problems and found that I was not the only one! There was a simple solution posted for a similar issue. All I had to do was delete my blutooth connection within my phone (motorola H700) and then reconnect the thing (password/code: 0000) and it worked! No more constant disconnecting and reconnecting. Ta dah!
Mar 23, 2009 | Motorola Mobility H710 Bluetooth Headset
Disconnect and connect on LG VU
i had the same devices and problem and found that connection quality was improved by turning the phone off for about 30 seconds and then turn it back on. Basically "restart" the phone. Hope you have the same success.
Dec 31, 2008 | Motorola Mobility H710 Bluetooth Headset
Constant beeping / connect/ disconnected
you need to turn off your bluetooth on your phone,cause as long as its on,its going to try to reconnect to your phone
Aug 27, 2008 | Motorola Mobility H350 Wireless Headset
Bluetooth
try master clearing and resetting the phone
Aug 14, 2008 | Motorola Mobility RAZR V3
LG HBS-700 Bluetooth Headset Logo
26 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
