Question about Marbles MR311 - Skinning Tool
My Marbles fixed Knife was left outside in the rain and blade is now stained. How do I clean it up?
Knife left out in rain for a day and now blade is stained with black tarnish
How do i fix toner stain on printout and photocopies? please what might be the cause of the dot stains?
There are several reasons for stains on a Laser printer or photocopier
1. Clean all rollers. Fuser; transfer and pickup.
2. Ensure the toner is clean from outside.
3. Hope the Toner is not refilled and Is not leaking.
4. Clean paper path.
Mar 08, 2016 | Office Equipment & Supplies
I left a clay pot on my patio glass table top. It now has square stain. How do I make it gone? The stain is not raised, the edges are not smooth. They are light gray. The pot sat on the table...
Typically MURIATIC ACID is very useful in cleaning stains from masonary and should work to clean a sudo-masonary stain off of glass. MURIATIC acid is normallly in stock at just about all hardware/big box home improvement stores
Aug 29, 2011 | Robert Yick Co. RanRYC168 Gas Kitchen...
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I can't open or refill the fat max. Lost the instructions.
If it is a 10-816 then Knife swivels open for easy blade change and clean out - no tools required, much like 10-999
If it is a 10-778, you don't really open it. You press little button on left side, behind the blade wiper, and this releases blade. Push red button on rear of knife, to open blade storage
if it is a 10-999 then press the button on rear and rotate the two halves.
Oct 29, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
2004 Jeep rain sensing wipers continue to run regardless of setting or amount of rain
a couple of thoughts:
Has your windshield just been replaced?
The sensor is up by the rear view mirror, is it plugged in all the way?
Do you have the right size wiper blades on your vehicle? (too short of a blade misses the rain sensor and does not wipe it clean)
How good are your blades? ( as above, to turn off the rain sensor the blade needs to wipe it clean)
The rain sensor works by projecting multiple inferred beams to the inside of the windshield, like a prism, they reflect back to collectors. when there is a water droplet on the outside of the windshield it changes a beams trajectory and it misses the collector thust turning on the wipers.
(yes, this all happens in that little sensor up by the rear view mirror.)
check to make sure the wiper switch is in the right position.
also....I've seen rain sensors not work properly when the hood or doors are open.
hope this helps
Feb 01, 2010 | 2004 Jeep Grand Cherokee
Remove oxide stains from a pocket knife blade
you could try a very weak solution of acid and water mix making sure not to scratch the blade, when the stain is removed smear a film of light oil over the blade hope this helps smirf617
Jun 02, 2009 | Victorinox Swiss Army Tinker Pocket Knife
Ceramic top
try flat blade scraper blade if no help to fix it new top
Jun 13, 2008 | Frigidaire FEF366 Electric Kitchen Range
XEROX DOCUCOLOR PRIN 12
Check the blade (knife) , maybe dont clean all residues, sorry form my english, check the fuser roll, this roll have a teflon, mabybe need change!
Dec 26, 2007 | Xerox DocuColor 12 Printer
Rain got inside
Water damage irreversible - may work sporadically after drying
Aug 16, 2007 | SanDisk Sansa e250 MP3 Player
Marbles MR311 - Skinning Tool Logo
444 people viewed this question
Top Marbles Hunting Experts
Peter
Peter
Carl Wiehe
Carl Wiehe
Bruce Mommaerts
Bruce Mommaerts
Are you a Marbles Hunting Expert? Answer questions, earn points and help others
