Question about Naxa "NT-1506 16"" Widescreen HD LED Television, Built-In Digital TV Tuner"
Comcast remote code doesn't work for naxa 1506 tv what will
Code 11998 doesn't work for naxa 1506
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
I have no remote for the tv,so i need the code for a naxa 15.6inch led tv. Ill enter it into my direct-tvs remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order.Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window.It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 17, 2015 | Naxa 15.6 Inch NT-1506 12 Volt AC/DC...
Set up
About which setup you are talking about. Universal remote control setup. If so, try these links.
May 20, 2013 | Televison & Video
Universal Remote Control Numbers needed for NAXA TV Model NT-1506
0483,0291,0382,0957,0000. Check these codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 18, 2013 | Naxa Electronics Televison & Video
Need a code for my Sony RM-Y16 Remote to split screen with my Comcast DVR
It is possible that this remote will not program to your Comcast dvr. Your DVR is probably newer than the remote and has new codes that the remote doesn't support. The only thing you can do now, is either purchase a new universal remote that supports both units. or use your Comcast remote to program it to your TV. the Comcast remotes are programmable.
Oct 07, 2012 | Sony RM-Y916 Remote Control
I'm trying to find a universal remote that will work my 13" naxa tv
Hi.
Unfortunately, naxa tv's aren't compatible with universal remotes, as they use a proprietary coding system for their tv's.
Your only hope is to contact Naxa's support department at support@naxa.com to ask about replacement remote.
This is directly from their website about the incompatibility with universal remotes.
I know you were hoping you could use a universal remote for your tv, but sadly that's not the case here.
I wish I could have given you better news, but it is the way they designed their sets, that's why universal's don't work.
I hope this helps you out in knowing what to do now, and have a good day.
May 25, 2011 | Naxa Electronics Nx-540 13 in. Portable TV
Need a NAXA remote code for dish network Remote
Hopefully you have resolved this issue, but if you have any additional problems or questions, here is some help. Follow the directions below, and that remote will be programmed right away.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Jun 16, 2010 | Naxa Electronics NX-556 19 in. LCD TV
Remote control codes for naxa tv model nx -524
You neglected to post the Remote's Make and Model. However, most Univ. remotes allow you to "Scan" the TV codes one at a time. You would do this and watch for the TV to turn off. when it does, you have the code and can store it.
Geno
Mar 05, 2008 | Televison & Video
Universal remote
call for a factory remote at1-800-736-6837
Nov 01, 2007 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Naxa "NT-1506 16"" Widescreen HD LED Television, Built-In Digital TV Tuner" Logo
Top Naxa Televison & Video Experts
Randy Handy
Trippy Tripp
Are you a Naxa Televison and Video Expert? Answer questions, earn points and help others
