My printer will not print anything in black,
Epson Nx430 wont print documents. have replaced black cartidge and nothing , done numerous nozzle cleans ( 1/2 empty now) re installed hardware nothing fixes it ? running windows 7
  • 35 Answers
Can you make copies stand alone in black? If it will make a copy in stand alone then try unistalling the printer and reinstalling the driver.
Posted on Mar 31, 2014
  • 36 Answers
SOURCE: New black ink, but wont print any black ink
Epson Printers are terribly designed. There is a known issue with them related to clogged ink wells. Below the cartridge the ink dries in the well and makes the printer unusable. I have seen this many many times and will NEVER recommend an epson printer. Most of the time I will have people go out and buy a new printer only because of the fact that you will be paying 50-70/hr labor for someone to FIX/Clean your printer. If you want to try to clean it yourself go ahead. I have done it in the past with varying success because it is more trouble than its worth to remove the inkwells and clean them properly. Buy an HP printer. The difference is that the HP cartridge is what contacts the paper directly. There is no inkwell inbetween to get clogged. When you buy a new HP cartridge you will replace everything between the ink and the paper. Epson is just a poorly designed product. Hack
Posted on Jul 09, 2007
SOURCE: Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Posted on Oct 28, 2007
SOURCE: won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Posted on Oct 06, 2008
  • 7 Answers
SOURCE: Unable to clean Epson C88 Nozzle
Hi,are the catridges genuine,if they're,head cleaning should remove the gaps unless the nozzles are clogged,theres a special solution for un-clogging in such cases.
Posted on Jul 01, 2009
fisherman816
  • 66 Answers
SOURCE: how to clean head printer nozzles on epson dx4400
maybe this will help...http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664&prodoid=46253282&infoType=Downloads&platform=Windows
Posted on Nov 08, 2009
One of my cartridges does not work
Start out by running a "nozzle check" in the printer setup screens. If the cyan isn't printing a full pattern, then do a "clean" pass, up to 3 times. If three times doesn't fix the missing color pattern, it's possible that the cart is defective, and isn't flowing ink.
Dec 22, 2015 | Epson Stylus Nx430 Small-in-One Printer
Epson RX620 printer will not print from black cartridge. I have all new cartridges and have run nozzle cleaning 4-5 times. Thanks. Gordon
Make sure the tape is removed from the new cartridges, remove the cartridges, restart the printer, place them back in, you might also want to clean the cartridge contacts if they are dirty.
Try reseting the machine to defaults from the menu.
Nov 01, 2008 | Epson RX620 All-In-One InkJet Photo...
I have an Epson NX400 printer but the yellow and black ink test pages are showing gaps and missing lines. I replaced both ink cartidges twice and did the head cleaning and nozzle check but nothing seems to...
Try to print something that is pure yellow and pure black. Set it to BEST PHOTO. If you see gaps or missing lines, your print head could be clogged. You will need to use a cleaning solution to remove the clog.
Jan 16, 2010 | Epson Stylus NX400 InkJet Printer
I have a c86 printer. The test on the 4 color ink patterns says nothing. I have cleaned the heads numerous times and have replace all of the ink cartidges twice. Same old situation. I have used Windex to...
You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully
into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any ink on the nozzle check, then there is hope! Repeat the head clean/ nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse, then repeat. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 01, 2009 | Epson Stylus C86 InkJet Printer
In view of leke0513's lack of interest in this problem, I think we may say it has been "solved by poster".
Mar 25, 2009 | Epson Stylus C88 InkJet Photo Printer
Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Dec 08, 2008 | Epson Stylus C84 InkJet Printer
MP530 will coply but won't print
sir,
Try to replace the cartidge maybe your cartidge is not fit to work properly and also the ink is not compatible with your printer
then after you replace the cartridge do the nozzle cleaning until its ok.
yours,
alecz
Apr 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
56 people viewed this question
k24674
