Question about Dishwashers
I need to replace the rollers on the top tray of my whirlpool adp6000wh dishwasher...
The rollers on the top tray of my whirlpool adp6000wh dishwasher have broken. I have ordered replacements- and they have arrived, but they do not seem to come off/out. How do I fit the new roller bracket, please?
SOURCE: I have an Electrolux dishwasher
sir/mam
try www.partnship.com.au
Posted on Apr 17, 2008
  • 171 Answers
SOURCE: Replacing Rollers on GE 725
Hi bklink_2000,
I'm Harvey the Master Plumber.
Your problem is: Now that you have the rollers you can't see how to get the old ones out or the new ones in. You are worried that if you forced the plastic piece out at the front of the steel rail you may bend the rail.
You're on the right track! The plastic end caps should pop off, that,s what they're for.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: Broken rollers inside top rack slides
We got rollers recently from Johnstone Supply, 501 Third Avenue, South, Nashville, TN telephone 615-259-3440 or 254-0702. I don't know the cost, but I'm pretty sure it was not $72. I suggest that you have the model #.
I am planning to buy some for another dishwasher at the moment.
Posted on Apr 12, 2009
SOURCE: whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Posted on Mar 13, 2010
SOURCE: my dishwasher is coming up
I just had the same thing, same model. After cleaning the filter out, the problem remained. I then read on another forum that it helps if you tilt the machine backwards for a few minutes (which involved pulling it out of the cavity in the kitchen). Did this and it now seems to be working. Hope this helps you.
Posted on Aug 13, 2010
Our whirlpool dishwasher make ADP6000WH/ADP6000IX runs for the first few minutes of each cycle the just kind of pauses and will not finish the cycle
Check your FLOAT... When it stops, Open the Door and see the Water LEVEL.
If the Water LEVEL is normal, then you have a problem with your Circuit Board
Apr 09, 2013 | Dishwashers
ADP6000WH/ADP6000IX--Whirlpool Dishwasher.(new) My problem--Water not getting hot--i have it connected to the cold water--should it heat the water ?
9d561c5b-7c7e-4515-8a01-fbfa8f762c34.jpgerror 3 not heating..on wix6000 /or / ADP6000WH
same boards .
rip out the the main mother board with all the black boxes ,and the transformer on it,,there is 1 black box its the biggest of them all ,next to the fuse with the blue cover on it ,with care take the black cover off with a screw driver carefully, not to damage the lower half of the internals,the lower section must not be damaged all ,once the cover is off you will see a copper coil on one side and on the other a set of breaker points ,at the end of the points ,get a screw driver and push in the outter point inward just a fraction,and bingo it will work again,of coarse its a temp solution,you will need to get a new breaker box from tandy or dick smith or simlar place to keep it going long term ..
hope this helps guys and gals ,please take extream caution when working on such dangerous power sourses ,and always make sure the power cord is removed before and repairs or tweeks..
cheers
Sep 30, 2010 | Whirlpool Dishwashers
Whirlpool ADP6000WH This dishwasher does not clean and leaves soap in dispenser. Tried other products but same result leaves most of the soap in dispenser. What could be the problem, machine is 8 months...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is coming up with a error 4. my dishwasher is a whirlpool ADP6000WH/ADP6000IX please help
Aug 05, 2010 | Whirlpool Dishwashers
Hi, I have a Westinghouse ADP6000WH dishwasher and...
You have to check the slider rails. If you watch the there be a different slot. You can remove and place it in that area.
Otherwise remove the top rack and run as special cycle for this dishes alone!!!
May 21, 2010 | Dishwashers
Whirlpool ADP6000WH Fault Code err 2
Hi, i have had my new dishwasher for less than 3 hours and is doing the same thing. Not happy Jan!!!! I have dishes everywhere, stuff out of the sink cupboard and a open house in 2 days. Watch out retravision in the morning!!!!!!! Did you get a solution to yours??
Jan 01, 2010 | Whirlpool 24 in. DU920PW Built-In...
What does it mean whirlpool adp6000wh err 4 message code
Error 4 means" too much inlet water", turn inlet water tap down.
Aug 25, 2009 | Whirlpool Dishwashers
Whirlpool dishwasher ADP6000WH Error 3
Jan 15, 2009 | Dishwashers
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
