Question about Vehicle Parts & Accessories
3cyl 993cc daihatsu engine starts and runs then shuts down could this have something to do with the fuel cut solonoid
Can keep it going by quickly applying choke
If you can keep it running with the choke set, your engine is starving for fuel, your fuel filter, or carb is clogged. disconnect the fuel line to the carb and check for flow. Fuel cut would do just that, cut ALL fuel so choking would not matter.
Posted on Mar 31, 2014
Why does my 1990 Daihatsu charade want to cut out and stall when giving throttle unless it's in high rpms it doesn't want to go we've replaced the fuel pump and filter could it be the injectors?
Daihatsu Charade low idle problems Questions & Answers ...
www.fixya.com > ... > low idle problems > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks low idle problems questions and answers. ... but idles unevenly with foot on accelerator. does not want to accelerate. please . ... problem daihatsu cherade 1991. when the airconditioner is on the car stalls when changing down to a lower . ... 1990 daihatsu applause 101a 1.6lt 5spd manual.
Daihatsu Charade car keeps cutting out when stop ... - Fixya
www.fixya.com > ... > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks car keeps cutting out when stop questions and answers. ... 1997 Daihatsu Charade CS G203 1.5i manual stalling when warm ... gear) while accelerating or when coming to a stop and you take it out of gear and ... 1990daihatsu applause 101a 1.6lt 5spd manual car starts normaly. when auto ...
Nov 17, 2015 | Daihatsu Cars & Trucks
Daihatsu charade 993cc 3cyl
fuel system problem..pump..or air right in th fuel system!?
Mar 30, 2014 | Vehicle Parts & Accessories
95 Ford Escort Starter keeps running
it is the ignition switch is shorting out.
Dec 15, 2012 | Cars & Trucks
1990 charade carby 3cyl seems like it starved off fuel.runs good then brakes down.then runs rough and comes good again.????
You may have a piece of dirt floating around int e carb float bowl, suggest you clean the carb first.
Jun 06, 2012 | 1990 Daihatsu Charade
I have just fitted a secondhand 306 turbo deisel engine into my 306 as the old engine blew up. This new engine was slightly different. The problem i'm having is that the injection pump is slighty different...
Hello. Questions: 1) Is the solonoid that you are referring to on the fuel bar, or the fuel line? Usea test light to determine whether there is power to it. If there IS power, the solonoid is cutting off the fuel. If there is no power to it, provide power to it and see if the fuel is getting to the fuel bar. 2) Can you hear the fuel pump running? 3) What was the difference between the old engine and the replacement? Is it the year model, or something else?
Apr 26, 2010 | Peugeot Liberte Cars & Trucks
My dodge ram truck will not turn off, it continues to run. A 1989 truck dodge ram 1989.
if its diesel there is a fuel shut off solonoid that goes bad u can use ur fingers to lift the arm and the engine will die. the solonoid is located on the drivers side toward the rear of the engine. the arm points strait down. pull it up to shut the fuel up (caution sometimes the arm will spring up snappng ur fingers keep fingers underneath the solonoid arm
Mar 21, 2010 | Dodge Ram 50 Cars & Trucks
Air/fuel mixing screw... where is it?
http://www.scribd.com/doc/7577738/Daihatsu-Engine-Manual
also - Take down the Vin number - call the local dealer and ask them - also ask about any recalls or service bulletins.
Dec 28, 2009 | Daihatsu Charade Cars & Trucks
Specs for 1992 3cyl diahatsu charade ignition timing
Timing set with vacuum hoses disconnected and blocked is 5° advanced when flywheel dimple lines up with notch plate.
centrif wieghts 10.5° @ 2800
vacuum two stage 11° @ -320mmHg.
Feb 19, 2009 | 1992 Daihatsu Charade
Daihatsu hijet 4wd van 1985 model 3 cyl 4 stroke 993cc valv tmg
If the belt has slipped you might be in trouble, becuase it's an interference engine.
Jan 30, 2009 | 1992 Daihatsu Charade
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
