Question about Chevrolet 1988-1996 Cheyenne Gas Fuel Filler Neck FN506 FULL
Chevy 350 surging rpms
My pickup's rpm's surge at around 1750 to 2000 when at highway speeds (65-75mph). O'reilly Auto ran error codes in response to check engine light on. There were 4 different "solutions" to the problem and I am hoping to narrow it down even further. I have had this problem for a few years. The problem comes and goes but it tends to be more prevalent during hotter, longer running drives (Summer months). The truck runs fine aside from that.
2 Suggested Answers
  • 55 Answers
SOURCE: '98 S10 4 cyl. 5 speed: Sudden high idle, now surges.
Go to your local shucks or auto zone and they can check any codes behind your check engine light and it's free. It sounds like one of two things a O2 sensor or your mass airflow sensor but they will tell you for sure
Posted on Oct 02, 2009
RPM surges about 500; worsened progressively. After a 1 hour wait, problem appeared to disappear.
Could also be EGR Valve or THROTTLE POSITION SENSOR or FUEL PRESSURE REGULATOR.
May 15, 2016 | 2009 Nissan Altima
This engine has a surge; AT 35-45mph,it's a bit more prounounced, not as bad, but still there at 60mph. As the tach goes up some, then down, so does the motor, up then back down, etc.Any ideas?
About 73,200 results (0.82 seconds) Search Results
    Surging While Driving Between 40 and 50 MPH : Chrysler ...
    repairpal.com > Problems > Chrysler > Town & Country
    Around 35 mph (common street speeds) the engine will sometimes surge with noticeable tach fluctuations. ... I have a surge when coasting around 40-45 mph.
    Enginge surges RPMS drop while driving [Archive] - Chevy ...
    forums.trailvoy.com > ... > OEM Issues
    Mar 17, 2012 - 19 posts - ‎7 authors
    [Archive] Enginge surges RPMS drop while driving OEM Issues. ... I so hope somebody has a clue as to what is causing my '02 Envoy's (182k) engine to ... I'll be driving and when I get up to around 35 - 45 MPH sometimes my ...
    Hesitation and bucking on acceleration - F150online Forums
    www.f150online.com/...engines/476391-hesitation-bucking-acceleration....
Feb 09, 2016 | Cars & Trucks
2003 protege surges in rpm
When you say " surges in rpm" you mean it surges when you give it gas, press down on the accelerator. It could any one of a dozen reasons for this; dirty air filter, dirty gas filter, foiled spark plugs, ignition problems, faulty fuel regulator faulty speed sensor, etc. Have the car's computer scanned for trouble codes which will identify where the problem is. Auto Zone and Advance Auto will do a scan.
Jun 12, 2014 | Mazda Protege Cars & Trucks
Oct 02, 2009 | 1998 Chevrolet S-10 Pickup
22r carb dumping fuel at 2500 rpm will not pass smog.Was rebuilt and is in smog specs. at idle.
Fill the tank up but do not top off.
Ran the trunk for 15-20 minutes on the highway and recheck the fuel surge condition at 2500 rpm.
If it stop surging then you has a weak fuel pump.
Change the fuel filter will also help.
Also check the fast idle setting.
If everything checks out then set a smog check appointment in the EARLY MORNING.
Jul 05, 2009 | 1986 Toyota Pickup 4WD
96 Jeep Cherokee RPM Surge While Driving
If the problem began before you changed the plugs that they are likely OK...Some engines "like" certain brand plugs better than others. You may have a weak ignition coil. Poor spark will generally show up at higher rpm's. Spark should be blue and have good "snap" to it and should easily bridge a 1/4" gap or better. If fuel was contaminated, it should show up at lower rpm's as well. System cleaners sometimes work but often are added far too late to do any good. (tank can hold up to a gallon of water without noticing it.) I use 3oz of acetone and one oz marvel oil per 10 gallons of fuel about once a month...cheaper and more effective than most cleaners. (and does not "melt" gaskets and seals as legend has it) The vehicle speed sensor can also give you problems but needs testing to determine if it's got any problems.
It's difficult to diagnose by remote control, but I hope you benefit form something here!
Jun 12, 2009 | 1996 Jeep Cherokee
Engine surges at rpm over 1500
Look for a vacuum leak (lines and intake), Is the engine light on, were any codes present? A faulty EGR or IAC could cause the problem too. Check the throttle cable for any restrictions.
May 27, 2009 | 1996 Chevrolet Cavalier
1995 toyota pickup, surging at around 2000 rpms
Is the check engine light on?
A major cause of surging is either air leaks between the air flow meter and the engine intake manifold, or a bad or mis-adjusted throttle position sensor.
Feb 24, 2009 | 1995 Toyota Pickup
Power surges at highway speeds
it possibly is a faulty throttle poisition sensor
Dec 07, 2008 | 1994 Ford Explorer Limited
Chevrolet 1988-1996 Cheyenne Gas Fuel Filler Neck FN506 FULL Logo
344 people viewed this question
Top Chevrolet Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Chevrolet Measuring Tool and Sensor Expert? Answer questions, earn points and help others
