Question about Dell Computers & Internet
Set date time
Everytime i shut down and restart the date and time changes in dell inspiron
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
I think you need to check BIOS Settings.. and need to change the BIOS Battery
Posted on Mar 30, 2014
SOURCE: SONY VAIO CMOS BATTERY LOCATION
Correction...
The CMOS battery is located under the system board, and is not accessible from under the keyboard.
The keyboard has to be removed in order to change the CMOS batter, (another reason why I don't like Sony laptops.)
Posted on Mar 27, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Posted on Jul 22, 2008
SOURCE: sudden shutdown dell inspiron 6000
hi, i have something strange found in my inspiron 6000:
it looses SMD-parts in the dc-power-converter!
...strange isn't it?
maybe are the suddenly shutdowns the beginning of this ****!
you need someone who knows good soldering....
...and maybe someone can tell me which kind of parts the mine d6000 has loosen :oD ?
it came back from dell *without*...!!!
...please can someone post me a foto?...
thanx, lapdoc
Posted on Dec 17, 2008
SOURCE: dell inspiron 1501 shuts down very often
is the laptop running unusually quiet? when you start it up hold it up to your ear and see if you can hear a fan spinning. its not uncommon for a laptops cooling fan to come from factory jammed. if its stuck you can usually dislodge it with a firm smack (after the laptop has been cut off and battery removed, wait a few seconds to make sure the hard drive has spun down).
Posted on May 11, 2009
  • 30 Answers
SOURCE: Dell Inspiron Mini 10 Not Shutting Down Properly
There could be a corrupted file. I would try to give dell tech support a call
Posted on Sep 21, 2009
Laptop date and time setting get disturbed automatically when i reboot my laptop
When you boot up and the Date & Time is wrong then you correct the Date & Time, then when you shut down and boot up again the Date and Time has changed. This is an indication that the BIOS battery is flat and you need to replace the BIOS battery. Install a new BIOS battery, go into the BIOS setting and set the Date & Time etc. and the new battery will keep your settings stored in the BIOS.
Feb 09, 2012 | Dell Inspiron 1464 Notebook
Got Dell Inspiron 2650 2002 from a friend, free. Want to restore to factory settings. How? Installed Windows XP and Norton Anti Virus
Hi and welcome to fixya!
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
  • 1 Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
  • 2 Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
  • 3 Scroll down to "Repair Your Computer" and press "Enter" to access the DataSafe local backup screen. Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
  • 4 Click the "Restore without preserving new or changed files" radio button and click "Next." Click "Next" three more times and click "Restart" to restore the disk drive to its original condition. Follow the on-screen prompts to set your operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
  • 1 Insert the Dell recovery disk in your Inspiron's optical drive and close the "AutoPlay" window when it appears. Shut down any other open programs. Click "Start" and select "Restart."
  • 2 Tap "F2" as soon as the Dell image appears on the laptop's screen. Scroll to the "CD-ROM" option and press "Enter." Tap any key when you see the "Press any key to boot" option.
  • 3 Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
  • 4 Follow the instructions on the screen to choose the Inspiron's operating system options. Click "Finish" and remove the recovery disk from the optical drive. Click "Start" and select "Restart."
Hope this helps!
Takasashi
Jul 19, 2011 | Dell Inspiron 2650 Notebook
When booting up, the screen says "hibernating," with the "refreshing" circle spinning & spinning. I've tried shutting down & turning the ower off, but to no avail. Any ideas? Thanks
go to bios setup check the date and time if not corect then set date time save setting exit setup and check ..hope it will be okie..
if same format ur system ...Thanks
Sep 05, 2010 | Dell Inspiron 1525 Laptop
Everytime we boot up our computer it says press f1 to do something and f2 to enter setup mode?
generally an indication that something is wrong in the system setup. Press F2 and enter setup, check the time and date settings and the system event log (If BIOS has one) for incorrect settings, also check and see if the BIOS shows a hard drive installed.
If time and are wrong, set them to correct and save settings. If system keeps losing time and date after power is removed, then the backup battery may need to be replaced.
If HDD is not detected, then reseat it. If still not detected replace it.
Dec 10, 2009 | Dell Inspiron 600m 1.6GHz Pentium M...
Sep 21, 2009 | Dell Inspiron Mini 10 Notebook
Touchpad settings reset to default after computer shuts down
What model laptop do you have?
I know some laptops come with a Power Management utility which controls various profiles. If your computer is setup with a certain profile maybe this is what is causing your computer to change settings everytime you reboot.
You may also be able to change this setting in the BIOS. Check there for any trackpad settings.
Jul 29, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Mar 22, 2009 | Dell Inspiron 530 Desktop Computer
Dell inspiron 1501
Hi there
Take the battery out and start the laptop up on AC power only, set the correct date, time and time zone, shut down the PC and remove the power jack, wait about 30 seconds then power it up on AC only again, If the date and time has changed the the cmos battery has run out and needs replacing. If it keeps date and time the problem is the battery or the powerboard controller that charges the battery is defective. If the battery is getting a charge, run the battery completely out of charge, then try to charge it again.
Good luck and thanks for using Fixya!!
Feb 22, 2009 | Dell Inspiron 1501 Notebook
Cmos battery dead - needs to be replaced
Sounds like you need to change the CMOS battery, the time being wrong everytime you boot is a good sign but also it losing its settings in bios is also another sign
Dec 26, 2008 | Dell Inspiron 8500 Notebook
How to keep number lock on after comuter is shut down and restart
  1. Start the registery editer (regedit)
  2. Go to HKEY_CURRENT_USER \ Control Panel \ Keyboard \
  3. Double-click the value InitialKeyboardIndicators, and enter 2 as it's Value data
  4. Close the registry editor
  5. Log off, or restart Windows for the changes to take effect
Dec 16, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
