Question about Vehicle Parts & Accessories
Daihatsu charade 993cc 3cyl
Engine shuts down after a few minutes could this be a faulty fuel cut solonoid
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Fuel system problem..pump..or air right in th fuel system!?
Posted on Apr 01, 2014
Why does my 1990 Daihatsu charade want to cut out and stall when giving throttle unless it's in high rpms it doesn't want to go we've replaced the fuel pump and filter could it be the injectors?
Daihatsu Charade low idle problems Questions & Answers ...
www.fixya.com > ... > low idle problems > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks low idle problems questions and answers. ... but idles unevenly with foot on accelerator. does not want to accelerate. please . ... problem daihatsu cherade 1991. when the airconditioner is on the car stalls when changing down to a lower . ... 1990 daihatsu applause 101a 1.6lt 5spd manual.
Daihatsu Charade car keeps cutting out when stop ... - Fixya
www.fixya.com > ... > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks car keeps cutting out when stop questions and answers. ... 1997 Daihatsu Charade CS G203 1.5i manual stalling when warm ... gear) while accelerating or when coming to a stop and you take it out of gear and ... 1990daihatsu applause 101a 1.6lt 5spd manual car starts normaly. when auto ...
Nov 17, 2015 | Daihatsu Cars & Trucks
3cyl 993cc daihatsu engine starts and runs then shuts down could this have something to do with the fuel cut solonoid
If you can keep it running with the choke set, your engine is starving for fuel, your fuel filter, or carb is clogged. disconnect the fuel line to the carb and check for flow. Fuel cut would do just that, cut ALL fuel so choking would not matter.
Mar 30, 2014 | Vehicle Parts & Accessories
1990 charade carby 3cyl seems like it starved off fuel.runs good then brakes down.then runs rough and comes good again.????
You may have a piece of dirt floating around int e carb float bowl, suggest you clean the carb first.
Jun 06, 2012 | 1990 Daihatsu Charade
95 charade . where do i find the mark on the
you have a leaking fuel injector if it runs after shut off. if its an other than U.S. model with carberator then the idle is set to high or the fuel shutoff solonoid is stuck/leaking.
May 12, 2010 | 1992 Daihatsu Charade
Air/fuel mixing screw... where is it?
http://www.scribd.com/doc/7577738/Daihatsu-Engine-Manual
also - Take down the Vin number - call the local dealer and ask them - also ask about any recalls or service bulletins.
Dec 28, 2009 | Daihatsu Charade Cars & Trucks
Specs for 1992 3cyl diahatsu charade ignition timing
Timing set with vacuum hoses disconnected and blocked is 5° advanced when flywheel dimple lines up with notch plate.
centrif wieghts 10.5° @ 2800
vacuum two stage 11° @ -320mmHg.
Feb 19, 2009 | 1992 Daihatsu Charade
Daihatsu hijet 4wd van 1985 model 3 cyl 4 stroke 993cc valv tmg
If the belt has slipped you might be in trouble, becuase it's an interference engine.
Jan 30, 2009 | 1992 Daihatsu Charade
Firing order of a daihatsu charade 3cyl 1995 model
If you find this Info Helpful Please Rate Me as It Helps me to reach the Expertise STATUS that I have Worked 30yrs to get to LoL Thank You Very Much and Have a Great Week!!
Firing Order: 1 - 2 - 3
Base Ignition Timing
Note: With the T terminal Shorted.5 +/- 2 deg BTDC
Ignition timing should be checked and adjusted, if necessary whenever spark plugs are replaced or any distributor maintenance is done. Ignition timing should be 3-7°BTDC at 750-850 RPM with the engine check connector terminal 11 (brown) shorted, Fig. 1. The engine check connector is located near the top of the transaxle.
Jan 21, 2009 | 1992 Daihatsu Charade
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
