Question about Office Depot Ativa DQ60M Shredder
Stripped gear I want to buy a replacement gear. Where can I buy one?
Is it possible to buy new gears for texet cc412n
we have no idea if the company makes or sells replacement gears . check their website.
Oct 04, 2016 | Office Equipment & Supplies
Shredcare com
They can but economically depends on the value of the unit and the make and also if the parts are avalible to buy. Normally the gears can be replaced by buying kits offline. The gears are normally attached using a Cir-clip round ring holder or a split pin, should be straight forward repair.
Aug 14, 2014 | Office Equipment & Supplies
Replacement gear required
There is a YouTube video on this.
Dis assembly and Repair of a Fellowes paper shredder - YouTube
www.youtube.com/
My fellowes paper shredder stripped a gear. Here I open it up and fix it with out needing to buy replacement parts.
Jan 29, 2014 | Fellowes P50CM Shredder
Nead gear replacement
The large electronic store chain Best Buy owns the Dynex Product Company. Having dealt with other Dynex products in the past, you will probably end up having to throw it away and buy a replacement.
Nov 24, 2013 | Dynex Cross-cut Shredder
Why did the speedometer quit working?
The sensor on the front wheel is broken or the cable became disconnected.
Mar 20, 2012 | 2000 Harley Davidson FXST Softail Standard
Where to buy a magic bullet base gear?
Hi Pamela... Magic bullet base gears can be purchased from amazon (my recommendation). Enter this link Healthy Blend of Power Precision and Value and choose carefully which one fits (by shape, size, price etc). I hope this was helpful. enjoy
Jan 15, 2012 | As Seen On TV Magic Bullet Food Processor
Norelco 8100 Series Motor/Drive/Gear Assembly
The gear tips are not available from the manufacturer. You will have to replace the whole assembly. Your other option is to but a used model of the same type off of ebay and take the gear stems off of it.
Dec 31, 2011 | Norelco 8151XL Electric Shaver
When you put it in 4th gear in grinds and sounds like the chain is trying to jump off
There are a couple of stripped gears in the transmission. The case will need to be split to locate and replace the bad gears. Be sure to replace not only the stripped gear(s) but also replace any gears that the gear teeth mesh with. Even if they look okay, they were exposed to the same punishment as the stripped gear. If you din't replace the "good" gears you get to do the repair twice in just a short time. Please rate my answer. Thanks. tombones49_57.gif
Apr 06, 2011 | Factory bike Chrono SM 250 Motorcycles
Office Depot Ativa  DQ60M Shredder Logo
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
