Question about Thomson TD98 TOPLOAD DRYER 220-230 VOLT
Water leaking from bottom of washing mating when washing
AA class 6kg
How do i fix my NEC NW-961 (6kg)
May have a crack filler tube.
Apr 27, 2014 | Washing Machines
How to fix NEC NW-961 6kg
Good to know the washer is working fine.
You may also benefit from running the washer empty with a cleaning agent like this
http://www.rubbedin.com.au/Product/17/The-Magic-Range/Washing-Machine-Cleaner-
This is my Beko 6kg a class 1200 rpm washing machine. I'm looking for the quickest wash. It has a quick wash button but I can't seem to find a quik wash. Like a 30 minute wash??
The machine washing speed is not only TIME but WEIGHT... If you are able to push the Quick Wash, then that is the Quickest to get the job done "RIGHT"
Apr 08, 2013 | Washing Machines
Hi, we have a Beko 6kg AA WMA652S and its not spinning. It won't spin during wash or at the end. Any idea what's wrong?
the problem might be the panel or it might be the washer pump that brings water out after wash
Jul 07, 2011 | Washing Machines
I have a baumatic class a 6KG 1100rpm washing machine and it is showing error code F04 - what does that mean? How do I fix it? Please help Rachel
I have had this same problem - you need to clean the drain as a starting point. You can do this by removing the front panel at the bottom of the machine (you will need a Torx head screwdriver) then gently unscrewing the filter on the bottom right hand corner. Keep a tray underneath though - as water will flood out as you remove the filter! If the filter is full of fluff, you should be able to fix the machine by cleaning it out and then putting it back in.
Dec 19, 2010 | Baumatic Washing Machines
Hoover HNL 6166 6kg A+AA 1600 washing machine....smell of burning like burnt rubbber...........
Hi.
It is very likely you need to replace the motor brushes. These are the electrical conections in the motor that wear after a time. They are fairly cheap, uses-replaceable, and available from online appliance specialists.
Turn off water and unplug before removing top/ back pannel to access motor. ***** CHECK MOTOR TYPE BEFORE ORDERING PARTS ******
Sep 30, 2009 | Hoover AAA160 Front Load Washer
Hi I have a Hotpoint Ultima 6kg WMA 76 washing machine - had for 6/7yrs. It has just started leaking water from the drawer when it changes from the wash cycle to the spin cycle...have given the drawer and...
You need to check the pump filter, and clean same.
Remove lower rear cover, locate and remove large black hose, remove and clean filter inside hose.
Please rate my solutioon.
Thanks.
Jul 26, 2009 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Thomson TD98 TOPLOAD DRYER 220-230 VOLT Logo
20 people viewed this question
Top Thomson Washing Machines Experts
Garth Jackson
highlander28
Level 1 Expert
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
