Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
Repairing bissell proheat2 9400 pump
I need a video or step by step instructions to take out pump fix it and the replace it back.
Bissell 7920 cannot discharge cleaner solution
go to the web page instructional video and maintenance help for troubleshooting.
God bless you
http://www.bissell.com/how-to-videos/
Jul 19, 2012 | Vacuums
Tip
How To Fix Your Bissell Carpet Cleaner When Solution Doesn't Spray
If you have a Bissell Carpet Cleaner, and you're machine is not spraying water on the floor, there are several things that might be causing this. Here's a list of possible problems that might be causing the machine not to spray water:
It may be a problem with your pump belt. Bissell Carpet Cleaners use a belt that powers the pump to spray solution out. There are also a few other possible issues, but as a Bissell warranty station, the belt going bad out-numbers all other problems.
Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
If your belt is worn out or broken, here's a direct link to that belt on our website:
Bissell Pro-Heat, Pro-Heat 2 6960W Replacement Pump & Brush Belts
Here's a great video that will show you how to check, and replace the pump belt on your ProHeat carpet cleaner:
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt Video:
http://www.bissell.com/VideoRating.aspx?id=1555
If this was not the problem, here are some other things that you may check:
  • Make sure there is liquid in both the Tank-in-Tank and the SmartMix bottle. Both tanks must contain fluid or the machine will not spray properly.
  • Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
  • Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized and the cap will not make proper contact with the unit. If there is no liquid present, you will need a replacement SmartMix Bottle.
  • Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
  • Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. (Bladder or SmartMix bottle may be empty or the valve may be blocked internally.) Use a soft-bristled brush and hot tap water to clear any debris. Replace autoload assembly or cap/insert if necessary.
  • Check if the small rounded window tabs on the top edge of the Floor Nozzle are locked in their mating slots on the base of the machine, and not inadvertently lifting the tank up out of place.
If these suggestions have not resolved the problem you are experiencing with your machine, you might want take your machine to a local BISSELL Authorized Service Center. I really hope that this information was helpful to you. If you find what's wrong with your Bissell and have specific questions about how you can fix it, please just let me know and I'll be happy to walk you through step by step to fix any problem you may have on your Bissell.
Thanks,
Chris Jones
GoVacuum.com
on Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Free instruction manual for bissell 4104
I've found step by step video demonstrations for cleaning, belt replacement, basically maintenance of different appliances on "YOUTUBE" you might want to check it out. Just type in Bissell 4104 beater bar replacement. Hopefully there will be a video showing you exactly how to replace it properly.
Jan 04, 2012 | Bissell 4104 Bagless Upright Cyclonic...
Cord won't retract or pull out. It is out about half way.
  • This is a common problem with retractable cords. Now because yours is not all the way pulled out you may be able to get it to go back in by giving it a quick **** on the cord. Not a long pull , but a quick tug! and it may release the jam. If not it will need to come apart and fixed. I will need the make and model in order to give you step by step instructions on this. Bissell makes many different makes and models and they are all slightly different from one another. so if this works for you great, if not write back with the make and model and I will give you step by step instructions on how to do this.
Oct 13, 2010 | Bissell Vacuums
How do you replace the belt that turns the brush?
Hi There,
Here's a very helpful video that will walk you through step by step the procedure you need to follow to replace the belt on your Bissell ProHeat series carpet extractor.
Video on How To Replace The Pump Or Brush Belt on Bissell ProHeat Series Extractors
I really hope this is what you were looking for. If you have any questions, or need help with any part of this repair, please don't hesitate to use the comment field on this page and ask any question that you need.
If this helped you, please be so kind and rate my repair helpful, or leave feedback for me. This is greatly appreciated, and also helps other Fixya users with the same problem find this video very quickly.
Thanks so much,
Chris Jones
GoVacuum.com
May 06, 2010 | Bissell 8910 ProHeat Clear View Upright...
Bissell Proheat 1699-5 won't spray, belt ok
Hi There,
It sounds like to me that this may be your pump. The newer ProHeat 2X models actually have a Silinoid problem right now which is more common then the pump going bad, but if you have the original ProHeat series, then it sounds lik you have a bad pump.
Here's a link to a very, very helpful repair guide directly from Bissell that will explain to you step by step how to trouble shoot, and replace the pump if needed. I would be lost on the ProHeat series without this handy repair guide.
I'm pretty knowledgable now on these machines, if you need some help or some clarification on how to repair this, please feel free to reply to this repair by using the Clarification request form. If you found this helpful, please be so kind and rate my repair, and give feedback.
Here's the link:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-proheat-repair-guide.pdf
Thanks again,
Chris Jones
GoVacuum.com
Apr 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Can you please help me? I have a Bissell ProHeat
Hi There,
There are two tanks on the Bissell ProHeat upright carpet extractors. Here's a link to the instruction manual that explain step by step on how you need to fill the machine and where:
http://www.bissell.com/DownloadAsset.aspx?id=645
Please rate the repair if you found this helpful,
Chris J.
GoVacuum.com
Apr 14, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
CANT FIGURE HOW TO INSTAL NEW BRUSH BELT
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hi There,
Here's a link to a video demonstration on how to replace the belt on your ProHeat carpet cleaner. This shows you step by step eveything you need to know.
If you haven't already purchased the belts, here's a direct link to the exact belt for your steamer. There are two belts on your machine, a pump belt, as well as the brush belt.
And here's the link to the video repair demonstration showing how to replace the belts on your Bissell ProHeat:
I hope that this information was helpful to you. If it was, please rate the repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair.
Feel free to ask any follow up questions that you may have on this repair, I'm always happy to answer any follow up questions.
Chris J.
GoVacuum.com
Apr 12, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Trying to replace pump belt on bissell cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
]e6yu
Dec 08, 2008 | Bissell 1699 ProHeat Clear View Upright...
How to change belt on bissell proheat powersteamer
There is a video on the Bissell website on how to do this, click here for the link:
Video
Jun 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
64 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
