Whirlpool wfe1070bd how can i use only cold water
    Master:
  • 966 Answers
Abid, set it by selecting from hot, warm, cold options on the dial/button.
Posted on Mar 30, 2014
3 Suggested Answers
beltronic205
  • 1466 Answers
SOURCE: Whirlpool WFE1070BD washing machine. The water tap
Could be dirt in the inlet valve remove the hoses and check/clean filters @this section.
Posted on Apr 05, 2010
  • 1572 Answers
SOURCE: We can only use hot
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Posted on Jun 06, 2011
Whirlpool washer letting both cold and hot water in when I only ask for cold water...
The water valve is working. It only does as told. Faulty water temp switch or yank out the small board and clean the terminals then re insert it and see if maybe corrosion was all that it was. That is what I would try if it was mine.
Dec 22, 2016 | Whirlpool Washing Machines
User manual whirlpool washing machine WFE1070BD
The model number WFE1070BD is not the complete number to look up a manual. This model seems to have been for sale in Australia, so please go to http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/ifu/home with the full code from the sticker on the washer. Enter the commercial code and then the language in which you would like to read the manual and click Search.
If you add a comment with the full code, I may be able to give you the direct link to the manual.
I hope this helps.
Oct 22, 2011 | Washing Machines
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
C1965@HOTMAIL.COMHI WE HAVE A WHIRLPOOL WASHING MACHINE MODEL WFE1070BD ON THE SPIN CYCLE ITS SO NOISY AND NEVER USE TO BE CAN YOU TELL ME WHY THANKS
First problem could be a bra wire or something similar caught in the holes in the bowl or between the bowl.Also you could have faulty bearings.Have a close look and see if it is in the holes first.Let me know how you go.
Apr 19, 2011 | Whirlpool Washing Machines
I have a model WFE1070BD*CD,(5 months old) does this machine use cold water ? Both hot and cold taps were connected at installation but on delicate wash clothes are still very hot .
Check the hose connections on the back.My guess is the lines are crossed. Double check: Is the cold water supply piped to the cold inlet on the washer and the hot water piped to hot inlet? They may be reversed either on the hoses or in the wall.
To check the in-wall piping, feel the the hose bibb marked cold...well, is it? cold I mean. If it is hot, the pipes are crossed in the wall. If it's cold, check that the hose is running to the inlet marked C or cold, or is blue. If it isn't your inlets are crossed. Either way, switch the hoses and you should be good.
Dec 09, 2010 | Whirlpool Washing Machines
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Jan 10, 2008 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
