Question about Pioneer DEH-P86DHR
PIONEER DEH-P86DHR NO SOUND!!
I plugged everything in, it lights up but I get no sound. There is a wire that I thought was the remote wire, it is blue with a white stripe and it has a plastic tube shaped thing on it that says 0.5A on it but it doesn't have a fuse in it. Could that be the problem for the sound?
That blue wire is a remote wire that runs an external amp.if you have one,that alone will make you have no sound.if not your going to have to try one because i think you cooked the internal amp in your head unit.dose it smell burnt in rear of head unit? need rca cables,power wire to run from battery to amp also you must ground external amp should fix the problem.run power for amp right from battery with a fuse or cur.breaker about 8 to 10 inches from battery in power line running to amp.ground amp also hook up blue remote line to amp.run rca cables from ins on back of head unit to ins on amp .if you have all this already,and the blue remote wire is on external amp,and it dont work.then just try useing the internal amp.tape up ends on all wires not being used.if ideas dont work.go to ebay ,just picked up the same model for 60 bucks.it jams.good luck
Posted on Dec 31, 2010
    Scholar:
  • 80 Answers
With these units, the internal amplifier is an IC that fails sometimes. It can leave the rest of the unit working ok, bit will have no audio. There may be audio from the line level RCA's but not from the speaker outs. Smell the back of the unit to see if it smells burnt. Most of the time it will, but not always. The IC is usually something like a PAL007a or similar. If you are good at soldering, you can order the part, and change it yourself. If not, you will need to seek a technician to replace the part. You may also try an external amplifier and RCA's instead of fixing the IC.
Posted on Jun 15, 2009
  • aribie4112
    aribie4112 Jul 18, 2012
    would that be the same for the pioneer deh-1300mp
  • aribie4112
I have a Pioneer DEH-1300MP. Brand new. Just installed, and I have no sound. Everything turns on, even the remote works. But no music. Person who installed is 100% sure the wires were hooked up right. Is...
try checking the speakers and speaker wires for any shorts, grounds or bare wires. just one shorted speaker or speaker wire will shut off the audio completely.
Jan 28, 2011 | Pioneer Car Audio & Video
No audio on Pioneer DEH-1100MP
I'm having the same problem worked for a couple of days then just stopped playing music
Jul 17, 2010 | Pioneer DEH-1100 CD Player
My pioneer deh-p5500mp Car Radio
hmm.. thats a nice radio, not too shaby heheh...
Well your car radio should have a Blue wire with a white stripe for the remote, in case you are interested in the user manual (wich im guessing you dont have)
Go to:
http://www.nodevice.com/user_manual/pioneer/car_audio/deh-p5500mp.html
it has a diagram of the harness and it shows a blue/white remote wire, so im guessing that you bought it used and probably got a different harness with your car radio... but then again thats too weird
you could do a check to see if thats really the problem... just feed 12V From the power terminal of your amp to the remote terminal, that should turn your amp on and you should be able to listen to your car radio's output (id suggest not setting the volume all the way up when doing this XD)
Hope it helps
Jun 23, 2009 | Pioneer DEH-P5500MP CD Player
I installed a pioneer Deh P49001B car stereo in a 1997 dodge stratus with wiring adapter from best buy. everything works great until you switch on the lights. all power to stereo is gone.
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
May 13, 2009 | Pioneer DEH-P5200 CD Player
No sound
The IC amplifier of the stereo are damaged thats the reason of the lack of sound,
Apr 05, 2008 | Pioneer DEH-P6600 CD Player
Deh-p7900bt no sound
lol... i had the same problem...
there is a blue wire in the TRUCK ADAPTER HARNESS side.. thats the amp remote or turn on..
make sure to connect that to the blue or blue/white "remote" wire on the deck.. that should do it.. unless you fried the audio ic chip in the deck...
if you cant figure it out please dont rate me "unhelpful" thanks
Jan 05, 2008 | Pioneer DEH-P7900BT CD Player
Reconnecting Deh - P3000
HI. search pioneer no sound on this board. i have already walked another guy through this... if everythng works but no sound is outputted.. 99 times out of 100 the audio output ic "chip" is bad. Its a common failure for pioneer cd players as well as others. The part is about $20 if you know where to look... if you decide to repair this yourself you will need to be very skilled with solder and desoldering braid... let me know
Jul 18, 2007 | Pioneer DEH-P3000 CD Player
Pioneer DEH-P86DHR Logo
203 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
