Agfa drystar 5302
Printer Show lower tray jam but it does not pull the film. If it pull the film, film jam at the base of the upper tray. Please suggest the solution.
SOURCE: agfa drystar 3000
Dear my Friends,
oftenly there are 03 cause for this reason:
firstly the problem can cause from the Power Supply. you should check for all the led on Power supply unit is light or not. if all of them is lighted please change to next step.
secondly, maybe the hard disk can not boot because the OS of this printer have problem you need to re-install the software for this printer. regularly this cause often is the main cause for this problem because this printer will not stable if the electric is went out while printing 95% for this case must be re- install the software . this is the reason while Agfa always warning you should use a UPS for this printer.
Notice: just only this type drystar3000 have this problem. others type is ds5300 ds5302 ds5500 ds5503 ,. drystar AXYS can solve this problem by itseft.
Thirdly, the cause can be from the Main MEC + THEMIS main boards (seldom happen with this reason)
please help me to re-check again,
do let me know if you have any question.
Regards.
email to : baoagfa@vnn.vn or quocbao.vo@agfa.com
Vo Quoc Bao - Service engineer
Agfa Representative Office in Vietnam.
91 Nguyen Trong Tuyen Str, Ward 15, PhuNhuan Dist-hcmc-vietnam
Posted on Feb 27, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
Josue Pongco
  • 154 Answers
SOURCE: TOP TRAY JAMMED, PULL OUT TRAY,PRESS OK,KODAC ESP7
Call Kodak for this issue, because i think there is a problem on the Firmware of your printer.
1800 421 6699
Or try upgrading the firware at this site
www.kodak.com/go/esp7downloads
Posted on Aug 25, 2009
  • 21 Answers
SOURCE: oki b6200 paper jam
restart the printer or reinstall driver again.
Posted on Oct 08, 2009
  • 4 Answers
SOURCE: Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
Posted on Jun 25, 2010
Printer jam after first copy
  • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
  • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
If you need any technical help on printer then you can reach at here
Mar 08, 2013 | HP LaserJet 2300d Printer
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
AGFA Drystar 3000
System software damage, need to reinstall with the backup disk.
Dec 12, 2009 | Office Equipment & Supplies
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Note
  1. Pull the paper tray completely out of the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
    Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Agfa drystar 3000
Dear my Friends,
Regards.
Dec 03, 2008 | Office Equipment & Supplies
106 people viewed this question
k24674
