Question about Konica Minolta magicolor 2400 Laser Printer
KONICA MINOLTA 2430 DL - BLACK NOT INSTALLED, CYAN NOT INSTALLED
I have cleaned the chip of the toners many times, it used to work. but now it just keeps saying black toner not installed , cyan toner not installed. there is lot of black powder thrown out each time i close the lid. can anyone help
Unfortuanately, the only solution that I know of is to purchase new chips ($15 ea.) There are multiple websites that sell these. I had the same problem and have resolved it in this mannor. I tells the printer that it is a new toner cartridge. There is another post in 'fixya' that explains howt to disable the 'reading' capabilities of those chips. You have to go into your status display box, printer, mode setting, then uncheck auto toner replace and restart printer. It is supoose to do away with the 'reading'. I tried it BEFORE replacing my toner and it didn't work. You have to replace it first, then follow those steps.
Posted on Jun 16, 2009
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
2430 DL Kon/Min laser, b&w only
Hey
in printer menu you have to look up some setting and tell the printer to continue printing when toner emty, you'll find it in gualiti menu or engie menu, i dont remember exactly.
second i think you still need to have all toners installed, if C is installed but shows no toner, then you have to clean chip reader under the toner rack.
Sep 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Jul 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Error 2408
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Toner not installed problem Err: Line 2408
i have the same problem. my printer says all of the toner cartridges are not installed. i have taken each one out and returned them, and have rebooted the printer multiple times. nothing helps.
May 30, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 2430 DL Xtoner not installed
Check the toner contacts in the printer, you may find one either dirty , bent or broken.
May 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
All four toners are saying that they are not installed
Take out the chip reading contacts and cleant it with alcohol and air then put it back, shuld work. Toners are originals or refilled ?
Dec 07, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
340 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
