Question about Mitsubishi LT-40151 40 in. HDTV LCD TV
How do i update the firmware update mitsubishi lt-40151
Update firmware
I have a 40 inch Mitsubishi Lt - 40151 TV. The sound stopped working need some help getting sound going. Will a software update fix this problem?
Problem can be intermittent. In most instances, normal operation can be restored by installing a software update available on-line to the public at Support Mitsubishi TV under the "Support" tab. If this does not correct your problem, double check your setting and make sure the speakers were not turned off. If you are still having problems then you will need to replace the main board, or the pre amp board. Part# 938P103010. I hope this helps.
Feb 15, 2016 | Mitsubishi Televison & Video
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
Blue screen and flashing green light
These flashes are fault codes, and are known as blinking codes. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Blinking codes and details to many brand TVs are given in detail.
Oct 26, 2013 | Mitsubishi LT-40151 40 in. HDTV LCD TV
Blue screen on and blinking green light
Blue screen indicates no signal. Check its main board. Contact any service technician.
How to reset the tv
What is wrong Danielle?
Go to Menu and select what you want in terms of picture, sound etc
Aug 22, 2013 | Mitsubishi LT-40151 40 in. HDTV LCD TV
Need firmware update as stated in error message
You should be able to Update the Firmware from the IBM website:
http://www.ibm.com/us/en/
Good Luck!!!
Apr 23, 2013 | IBM xSeries 346 Server
Turns itself off when turn on by me
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)!
Please rate if this helps! :D
Replacing capacitors is ALWAYS the cheaper option, but you need to have experience it, or you'll create more damage than good!
Jun 14, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
No sound at all on Mitsubishi LT-52151. Fixed before by unplugging, waiting 30 seconds, plugging back in. Was occurring more and more often to the point of having to do this every time I would turn it on....
Just fixed this on my TV today! (after 2 months of the sound intermittently failing to turn on and failing completely yesterday) Go to Mitsubishi-tv.com. Go to support. Enter your model number. You will be directed to the documentation for your model which will include a zip file for a firmware update and a PDF file with instructions for installing the update. This fixed my sound.
Mar 02, 2011 | Mitsubishi LT-52151 52 in. LCD HDTV
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
How do i update the firmware to my sony ericsson w850i? procedures, pls. thanks
Accessing Firmware Information
To find out which firmware revision your phone currently has installed, select Menu > Settings > General > Update service > Software version. For more detailed software versioning information, perform the following:
Where < and > represents pushing the joystick left and right respectively.
Sony Ericsson Update Service
The firmware of the W850/W830 can be upgraded either over the air by selecting Settings / Update Service / Search for update or via the more traditional (and potentially cheaper) method of the Sony Ericsson Update Service. In order to use SEUS you will need to have internet access (preferably Broadband) and attach your phone to your PC via the supplied USB cable.
Note that the required firmware update drivers are present in the following directory after installing SEUS:
C:/Program Files/Sony Ericsson/Update Service/drivers
If you run into problems, you may wish to download and install Sun's Java Runtime Environment separately.
If the firmware update fails part way through, retry the SEUS. If the update consistently fails you will need to perform a Master Reset on your phone. It is likely that you will be required to perform a Reset All - a settings reset is unlikely to do the job. It is recommended to use a tool such as MyPhoneExplorer to create a backup of the data on your phone before performing a Master Reset. Note that you will still lose any games, themes or ringtones present in your phone's memory.
SEUS will currently install the following firmware revisions for UK phone brands:
W850
Unbranded UK (CDA102677/95) - R1ED001
O2 UK (CDA102677/58) - R1ED001
Vodafone UK (CDA102677/51) - R1ED001
Orange UK (CDA102677/36) - R1ED001
3 UK (UNKNOWN) - R1ED001
T-Mobile (CDA102677/26) - R1ED001
Oct 07, 2009 | Cell Phones
Mitsubishi LT-40151 40 in. HDTV LCD TV Logo
168 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
