Question about Refrigerators
My kitchen aid oven (model KDRP407HSS4) Display Board 4452999 does not display all the time!
The Display sometimes seems unreadable but some times it shows the correct numbers. Mostly they are all broken up
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
SOURCE: JENN-AIR MODEL D156B Electric oven
code f 0 means what?
Posted on Aug 25, 2008
  • 142 Answers
SOURCE: Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Posted on Oct 01, 2008
SOURCE: BLANK DISPLAY AND CLICKING SOUND
This is the main control board failing. My symptoms were identical (intermittent display and clicking), and eventually the clicking didn't go away and the freezer got hot. I replaced the main board yesterday and all is well (display fixed and no clicking). I was able to find the correct part number using the GE website (entered refrigerator model PD22S1S and then selected PDS22S1SARSS from the drop-down list). My part number was WR55X10656. The GE price was shown as $157.50, but I bought mine from ApplianceZone.com for $101.68. Hope this helps.
Posted on Dec 24, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Posted on Mar 19, 2009
My Kitchen Aid kdrp467kss09 oven's display is not working properly. everything else seems to work, but the small arrows for "stop"and"time" are lighted, and you can't put the correct time or even in...
From a tech position this is a tough one the display is fine you are getting a display it hooks to the User Interface which ties to the main control board if one were to take a guess based on experience I would say a bad UI called a Zodiac control not hard to change but not cheap either sorry I could not give you a definitive bad part this is the set back sometimes when dealing with computers all tied together
Feb 21, 2015 | Kitchen Ranges
I set oven temp. It seems to heat ok, during the bake cycle it beeps then shuts off, no display for oven function but the time display remains. Replaced the relay/display board but same.
the beeping is probably saying that set temp is reached just probably oven is still heating so dont turn it off look after an hour if it still on and very hot and worry about display changing its probably how the programmer wanted it to be
Aug 08, 2013 | Kitchen Ranges
Dim read out on oven.
Sounds like the transformer that powers the display board is shot. Unfortunitly, they are located ON the display board on most ovens. You will most likely have to replace the display board. Contact DCS, they will be able to help you. Have model # and serial # handy BEFORE calling, both are needed for them to help you. Voltage too.
Mar 30, 2010 | Kitchen Ranges
Wall oven controls do not light-up or function.
i cant call you but iv seen this a few times the display part of the board went out (you can still probably get it to cook but cant see the temperature) you are gonna have to replace the board.
Dec 12, 2008 | KitchenAid Architect Series KEBC107KSS...
Dual fuel kithen aid F 02
Welded element relay on the control board.
Brian
Apr 18, 2008 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn- Air SCE30600B
It's a bad capacitor on the clock/display board. The solution was posted elsewhere in FixYa. I had the same problem and was told I should replace the clock/display board, which would solve the problem, but costs about $150 plus labor. If you can desolder/solder small components on an electronic circuit board, you can fix this yourself. Mine was capacitor C3, originally a 68uF 35V component. I replaced it with a 68uF 63V as the closest one I could find at Jameco.com which was less than a $1. Lo and behold, my clock/display is back to normal! Saved a lot of money to fix it myself and I know it will happen again over time, so I know exactly what to do next time.
Jan 25, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Electronic Display
This is a common problem with Jenn-Air and Maytag that I have found. There is no way to brighten the display and usually requires the replacement of the Electronic Oven Control (EOC) board. I think this may have something to do with the placement of the board and possibly being damaged by heat from the oven over a period of time. Do you do a lot of baking? Do you use the self-clean mode for your oven a lot? These seem to be contributors to these boards failing like they do. I know of one person who has replaced the EOC 6 times on the same stove. I don't know if this is the advice you were looking for, but I hope it helps you.
Jun 17, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
