Question about Yahoo Messenger
When ever i try to login to messenger occurrring an error81003004
Messenger encountered connection problem.please check the connection and then click try again(81003004) that what am seeing when ever am try to login. but my net was good am able open all the sites. plz help me
    President:
  • 1,383 Answers
Okay
go to
C:\Program Files\Yahoo!\Messenger\Profiles
then delete all profiles from there .
Then restart your computer then check .
If still problerm remains first uninstall yahoo messanger from add remove program in control panel.
Then downlaod from here and install.
http://www.soft32.com/download_30.html
Posted on Jun 15, 2009
Messenger encountered a connection problem. Please check the network connection and then click "Try Again". (81003004)
Check your firewall and anti virus settings, Some programs block yahoo messenger from connecting to the internet.
Sep 09, 2010 | Yahoo Messenger
Getting error81003004
Try to download and install Pidgin from http://pidgin.im. Then try to login to Yahoo from within Pidgin
Jun 24, 2009 | Yahoo Messenger
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.
Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.
thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Jun 02, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Cant signt in yahoo messenger error81003004
f you have never had messenger on your PC before then the first thing you need to do is make sure you have the latest
Macromedia Flash Player installed. If you don't
have the flash player installed messenger will
not open and crash before you are able to sign in.
Please note: Use Internet Explorer to install the
player. You can get the latest Flash player, by
clicking here. >>
http://www.adobe.com/shockwave/download/...
and also Install the latest Java here >>>
http://www.java.com/en/download/index.js...
After you get those two things installed go here and get the 8.1 messenger >> http://www.freecreed.com/ymsgr-archive.h...
I do recommend you get the 8.1.0.421 version
as it is the most stable a bug free version
of messenger !!
When you download it just save it to your
desktop and then run the installer from there.
If you have XP just double click on it to start the install.
If you are on Vista you will need to Right click on it
(the installer you just downloaded) then click
"Run as Administrator" to get it to install correctly.
found on http://answers.yahoo.com/question/index?qid=20081012000725AALyvg7
Apr 28, 2009 | Yahoo Messenger
After i install yahoo messenger this script shows up ..
i cannot sign in to yahoo messenger. it keeps on saying "messenger encountered a connection problem. please check the network connection and then click "try again". (81003004
Apr 25, 2009 | Yahoo Messenger
Messenger problem
click the "messenger" menu and select "connection preferences" Select "Firewall with no proxies" click "Apply" you should see a message asking you to sign in again click "oK"
info found in yahoo help here is the link
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/messenger/mstanoconnect.html
Feb 26, 2009 | Yahoo Messenger
When i log on it says Messenger encountered a connection problem. Please check the network connection and then click try again (81003004)
Is this Yahoo messenger? if so,try this:
Click messenger / Choose connect via a proxy server/choose http proxy
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 09, 2008 | Computers & Internet
Yahoo Messenger Logo
147 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
