Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
No sucktion it stop picking up
Belt is strech doese not pick up diert
Hi! The brushes are needed to spin on carpet to agitate the carpet fibers and assist the motor with maximum pick up. If the belt is stretched you will need to replace it. This unit takes belt 562633001. Below are step-by-step instructions for replacing the belt on your Nano.
1. Lay the cleaner flat and flip it to expose the
nozzle base. The base should lay flat and face up.
Remove the five (5) screws.
2. Pull and lift the nozzle guard off.
3. Lift and remove the brushroll. Dispose of the
old belt.
4. Slide belt onto motorshaft.
5. Place new belt in area of brushroll without
bristles.
6. With new belt in place, pull and slide brushroll
into nozzle making sure that the brushroll end caps
are in the correct orientation. Rotate brushroll
manually to make sure belt is properly aligned.
7. Reattach nozzle guard.
8. Secure by aligning the three tabs in the
base slots.
9. Replace all five screws to secure nozzle guard.
Follow the link to order a replacement belt for your vacuum. Flat Belt Nano Upright
Hope this helps!
Mar 04, 2014 | Hoover Nano Cyclonic Compact Bagless...
My Bissell Pro Heat Pet will spray water but not pick it up when cleaning the carpet. Is there anything I can do to fix it? The furniture attachment hose picks up water well. It seems like it could be a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 13, 2010 | Bissell Vacuums
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brush spins but the the dirt is not getting into the bag. i cleaned the hoses now it's not sucking anything up.
If the motor is running you should get some kind of sucktion, if no sucktion or wont blow any air out, check the house making sure is clear of any obtruction, the best way is looking in the house by have one person hold one end and other pull the house straight and look to see any obstruction. if it seem clear, check the motor attach to the fan, yep you have to take the cover to the motor off with phillips screw driver in order to see what causing motor not to **** although the motor may not be attached to the fan; could be loose and not spining the fan to create any sucktion. hope that help some..good luck
Jul 12, 2009 | Vacuums
My kenmore hida filter vacuum cleaner no longer has the sucking ability it used to have. It is only 4 years old and has worked extremely well up until this week. The motor is functioning well, as is the...
well i've hade one come in a while ago and it didn't have good suction so I looked at the bag it was buljing w/ dirt so I put a new bag in it and it had better sucktion but still not good enough so I cheched the fabrick filter and it was dirty too so I washed it and it had even better sucktion so try the paper filter on the end too and if your vacuum still haves bad sucktion try looking if the hose is clogged buy putting your mouth on the end and blowing through it i recomend whiping the end off befor blowing if hard to blow it is clogged, if clogged i would put something thin like a metal rod or or a stirty stick to push the dirt out i'm sorry if my info didnt work out :D
Jun 12, 2009 | Kenmore Whispertone 23312 Bagged Canister...
No suction on wind tunnel vaccum cleaner
Your brush might be clogged with hair. while uplugged, flip over the vacum and check to see if there is any hair or string wrapped around the brush...
Jun 03, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Not getting sucktion to the hose. not picking up dirty water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
7t897
Dec 22, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Morphy richards 73340
Put broom handle down hose there will be a blockage.Put hand over vacuum inlet with hose removed if you have sucktion it is hose
Oct 11, 2008 | Vacuums
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
26 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
