Question about Lionel New York Central Flyer
How do I repair a lionel 99n signal
The mast is loose
Coupler will not stay closed on tender this was new out of the box
Contact Lionel Customer Service for a repair/replacement or take the tender to a Lionel Service station.
Jan 27, 2016 | Crafts & Hobbies
Why do I loose the signal on channel 26 only?
sounds like a weak signal might help if your antenna was on a mast for a better reception
May 05, 2014 | Vizio L32 32 in. LCD HDTV
My transformer did not work
The internal fuse is probably blown. Contact Lionel at Lionel.com for instructions on how to get a replacement.
Jan 20, 2014 | Lionel Cw 80 Transformer
Lionel toys
see attached pdf.
Jan 19, 2014 | Lionel Crafts & Hobbies
Check out these Lionel Customer Service Videos.
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6334
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6337
Dec 31, 2012 | Lionel 6-30068 North Pole Central...
How do I troubleshoot my inoperable turn signals, low fuel light, & horn on my 2010 Harley 883N iron sportster?
Hi Lionel, always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below. Good luck and have nice day. Harley Davidson Wiring Diagrams and Schematics
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 03, 2012 | 2010 Harley Davidson Sportster XL 883N...
How to wire a Lionel block signa lwith insulated track.
Only one outside rail has to be insulated from other sections. A hot wire goes to the signal block. The other wire from the signal block goes to the section of track with the insulated outside rail. When the train passes over the section of track with the isolated rail, a connection is made to the power supply common through the wheel axel. The other wire from the aux supply (common) is connected to the same common as the supply powering the rails. Power the block signal from an aux supply not rail power.
Aug 30, 2011 | Lionel Mpc 6-2163 Auto Block Signal C9
My lionel rw transformer won't run the train unless ithe speed control is turned 3/4 way up or better . Can this be fixed ?
Yes. Find a Lionel repair shop or bring it to a local hobby store that does model train repairs. You can contact Lionel for a list of repair shops.
Dec 25, 2010 | Lionel Cw 80 Transformer
1999 f150 turn signals and brake lights out. High mast still work
The signal lights work through a relay but the brake lights work through the signal switch, if both are out I think you'll find the problem is the signal switch.
Jan 19, 2009 | 1999 Ford F150 Regular Cab
Lionel New York Central Flyer Logo
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
